-   -   Jointed Arms for Ridetech 4 Link (https://www.lateral-g.net/forums/showthread.php?t=50870)
Smoker03 08-12-2015 01:48 PM
Guys, I have the Ridetech 4 Link in the rear of my 67 Camaro and wanted to see if anyone knew if there are any jointed arms out there for the kit similar to what Chassisworks and SC&C make for the CA kits. I know Ridetech has the full heim setup, but most of my driving is on the street with some auto-x and I have never had heims not make noise on the street. Open to all options.
Z06vette 08-14-2015 11:28 AM
I'm not quite sure what jointed arms are, I'll have to look up those other systems you mentioned. I chose to run the rubber bushing on the body ends of the link arms and the heims on the rear end side. Its not as quiet as rubber bushings all the way around, but the noise is very slight and only heard at parking lot speeds going over bumps.
JKnight 08-14-2015 01:23 PM
I'm guessing he's referring to the Currie "Johnny-Joint" style of rod-ends. There's also the Spohn Del-Sphere joints from SC&C. You can make your own link bars by welding the threaded inserts into some DOM and threading in the joints. Lots of options here...but may not be anything bolt-in.
