1972 Nova Ls2 Pro Touring
9 Attachment(s)
Item Location (City/State):CHICAGO,IL
Price:36,500 Description:1972 NOVA PRO TOURING FOR SALE IS A 1972 CHEVY NOVA PRO TOURING LS2. CAR IS 90% COMPLETE, ALL HARD WORK HAS BEEN COMPLETED, JUST NEEDS INTERIOR ASSEMBLY, WHEELS AND A FEW ODDS AND ENDS. CAR COMES WITH ALL OF THE INTERIOR TO COMPLETE (NEW), LESS SEATS. ALL PARTS ARE NEW IN BOX. NO TIME TO COMPLETE, ALL WORK WAS PROFESSIONALLY DONE. I WILL LIST EVERYTHING THAT IT COMES WITH, SURE THERE WILL BE THINGS FORGOTTEN BUT FEEL FREE TO CALL OR TEXT WITH ANY QUESTIONS. SAM...708-932-2129, CAR IS LOCATED IN CHICAGO, IL. BODY: NEW GM FLOOR PANS (FULL FLOOR PANS, SEE PICTURES). NEW GM TRUNK PAN NEW GM DOOR SKINS (SHAVED DOOR HANDLES W/ REMOTE DOOR/TRUNK OPENERS INSTALLED) NEW GM FENDERS NEW GM FULL QUARTER PANELS NEW GM COWL HOOD NEW GM TRUNK LID NEW GM POWDERCOATED WHEEL WELLS CAR HAS BEEN TAKEN DOWN TO BARE METAL, PAINTED (BLACK PURPLE PEARL METALLIC) AND BUFFED. THERE IS NOT AN IMPERFECTION ON THE ENTIRE CAR. ALL GLASS IS NEW (SMOKED GLASS), ALL TRIM IS NEW, COATED BLACK. FRAME/SUSPENSION BRAKES: COMPLETE HEIDTS PRO-G FRONT SUB-FRAME COMPLETE HEIDTS PRO-G REAR 4 LINK W/ADJUSTABLE COIL OVERS ON ALL 4 WHEELS FORD 9" (STOCK LENGTH)W 373 GEAR COMPLETE UNDERCARRIAGE HAS BEEN PAINTED AND DETAILED POWER RACK IDIDIT STEERING COLUMN (POWDERCOATED BLACK/ KEY ON COLUMN) WILWOOD 4 PISTON, 4 WHEEL DISC BRAKES, WILWOOD PROPORTIONING VALVE, WILWOOD MASTER. ALL LINES CUSTOM BENT AND INSTALLED. ENGINE/ TRANS: TRANS. IS A FLT LEVEL IV 4L60E YANK SS4000 CONVERTOR ENGINE IS AN LS2 ALUMINUM SHORTBLOCK FLYCUT PISTONS, MELLING OIL PUMP TRICK FLOW 7.5 PUSHRODS FEL-PRO .041 HEAD GASKETS ARP HEAD BOLTS COMP CAM 239/247 .624/.624 (LSL LOBES). TRICK FLOW 220 HEADS PORTED BY TEA WITH CUSTOM TEA 2.04 LS3 INTAKE VALVES, COMPETITION VALVE JOB, TEA GOLD DUAL SPRINGS. LS7 LIFTERS MEZIERE ELECTRIC WATER PUMP FAST 102MM PORTED INTAKE PTM 102MM THROTTLE BODY LS2 FUEL RAILS SIEMENS 60# INJECTORS (TUNED ON E85) SPEARTECH HARNESS, AMERICAN AUTOWIRE BODY HARNESS OPTIMA YELLOW TOP, TRUNK MOUNTED BATTERY DYNA-TECH HEADERS I WILL TRY TO UPLOAD PICS ASAP, NOT HAVING ANY LUCK DOING SO AS OF YET. |
Beautiful car. You have a bunch of "New GM" stuff listed and one is the Cowl hood. GM never used a cowl hood on a Nova so I'm guessing it is not GM ?
Price Drop
$35,000, Need To Move This
Price change
.....$33,000, need it gone before winter
Will Also Sell Rolling For $25,000(less Motor And Trans.) As I Have Someone Interested In Motor And Trans. Setup.
GM never produced a cowl hood but There are cole hoods that are stamped GM. I have a 2" that has the GM stamp on the underside.
pm's replied......
Really Need This Gone.....$30k
Very nice car, wish I had the cash.
Please call or text with questions...
708-932-2129, I do not log on as much as anymore I also only check emails on occasion being so busy with work. |
| All times are GMT -7. The time now is 07:33 AM. |
