-   -   Welding a used gas tank (https://www.lateral-g.net/forums/showthread.php?t=51227)
rjardy 10-05-2015 10:29 AM
Hey guys, I am looking to upgrade my fuel system and considering an in-tank pump. My tank is all but new but has had gas in it. Id like to weld the fuel return and the sump into this tank but have reservations about welding to a tank that has had fuel in it. Any recommendations on how to purge this and weld it safely?
Regards,
Rob
raustinss 10-05-2015 12:21 PM
It's like trying to take a s**t with your pants on. Can be done might be messy.cleaning it out and letting it air dry for a week obviously remove any and all parts that you can. Then be brave lol... Honestly take it to a shop and let them do it..if they will
rjardy 10-05-2015 12:34 PM
Sounds like I may be better off just buying a new tank. I like your analogy though!
Vince@Meanstreets 10-05-2015 12:49 PM
yep, they are so cheap now. Welding galv steel sucks.
Build-It-Break-it 10-05-2015 12:54 PM
Most radiator shops will clean them out and sometimes weld in what ever you desire. It's been done and isn't a big deal. Call a few and ask if they'll do it and pricing.
Galvanized is toxic when welded so just take proper precautions. Proper respirator etc.
bigkarz 10-05-2015 03:42 PM
fill the 1\5 way with water and dawn dish soap blow air in tank to mix repeat if still smells like gas poor it out and cut and weld
i did my tank and worked great
Musclerodz 10-05-2015 04:09 PM
If you have a plain stock tank, then just replace it. If you got a high doller tank like ricks then modifying may be something to consider. I purge my tanks with argon, but even then the pucker factor is high.
rjardy 10-05-2015 04:22 PM
Lots of great info here. Thanks for all the input. It's just a stocker so getting another one is only a $200 affair. On the same note, whats the best place to put a sump? Lowest point sounds right?
Musclerodz 10-05-2015 04:39 PM
they are cheaper than that. You can buy a tanks inc tank already ready to go very reasonable.
rjardy 10-05-2015 05:02 PM
Ill look in to that. Thanks
