-   -   FS- Hotchkis 2nd Gen Camaro/Firebird Sub Frame Connectors (https://www.lateral-g.net/forums/showthread.php?t=51286)
The T-man 10-14-2015 11:30 AM
FS- sold
Item Location (City/State): Sacto Norcal
Price: SOLD,,,,,,,,,,,Thank God himself.....
pickup in Norcal Sac / Chico / Bay area
Will drive and Meet
New in box never used <<<
Description: Hotchkis Part # 4012
Hotchkis Sport Suspension 4012 1970-1973 Camaro/Firebird Sub Frame Connectors. The Hotchkis Performance sub-frame connectors for 70-74 F-Body cars are designed to add rigidity to the chassis to improve vehicle performance by reducing chassis flex. Fabricated from 1.5 in. x 3 in. .120 wall rectangular steel these TIG-welded connectors are powder coated gloss black. Installation of these connectors does not require modifications or cutting of the floor boards. The rear mount is a weld in while the front mount is a bolt in with the option to weld. This is a must have finishing touch for any F-Body restoration. Features: Powder Coated Gloss Black Finish TIG-welded Fabricated from 1.5 in. x 3 in. .120 wall rectangular steel. Rigidly connects the front subframe to rear chassis frame rail which dramatically reduces chassis flex during hard cornering and acceleration. Does not require cutting or modifying the floor. Front is optional weld or bolt-on. Allows for front subframe removal if needed. Tucked-in design gives excellent ground clearance. Benefits: Improves vehicle handling. Improves vehicle traction. Reduced chassis flex.
Features and Benefits:
Reduces Chassis Flex
Improves Handling
Allows Harder Launches
Helps Reduce Body Rattles
The T-man 10-17-2015 11:44 AM
dropped price
euler 10-19-2015 09:44 AM
PM sent.
The T-man 11-06-2015 01:14 PM
still here
udloze 11-12-2015 05:42 PM
pm sent
The T-man 12-05-2015 02:14 PM
still here!
The T-man 12-10-2015 09:54 AM
ready to ship or deliver...:bump:
Vince@Meanstreets 12-10-2015 12:48 PM
Price: $225 + ship or
pickup in Norcal Sac / Chico / Yuba / Bay area
Will drive and Meet
Improves Handling
how far south on the bay are you traveling T?
The T-man 12-28-2015 12:45 PM
still here....:bump:
The T-man 01-20-2016 10:14 AM
Still in box...still looking for new owner!
