-   LSX Conversions (https://www.lateral-g.net/forums/forumdisplay.php?f=70)
-   -   MAF placement? (https://www.lateral-g.net/forums/showthread.php?t=51683)
jlwdvm 11-27-2015 08:59 AM
MAF placement?
I currently have my MAF placed between my throttle body and a 90 degree bend in my intake tube that I fabbed up out of 4" tubing. The 90 is needed to make the transition from a long straight piece that runs between the rad and the motor. The air cleaner is behind the drivers headlight....if all this makes sense. I have heard that the MAF needs to have a certain length of straight tubing before and after it to function properly. Texas Speed built my LS3 and supplied the MAF. The tech I talked to their made it sound like it didn't matter. Thoughts? I am thinking I may need to move the MAF into the straight section.
glassman 11-27-2015 09:21 AM
yes and no. GM requires 6-7 inches for the air to "straighten out", but there are solutions for that acording to Spectre/K&N, they make an air straightener or scrambler, i cant remember which. I have an LS and am redoing the air intake system on it and putting it near/behind the left headlight (2nd gen cam). Pics will be in my build thread soon (dis-traction).
jlwdvm 11-27-2015 10:44 AM
http://www.pro-touring.com/threads/1...ar-build/page7
#121 and 132 give you an idea of what I fabbed up so far.
Z06vette 11-27-2015 11:47 AM
From what I have read & seen on other builds, most are located in the middle of the long pipe running along the rad. Right in the area of the alternator, give or take. Thats where I positioned mine. The blade style MAF is sensitive. If you don't have a screen or "honeycomb" before the MAF, I would add one. You might be ok leaving it there, but if you have any tuning issues it might need to be relocated. Looks like you have a nice build going there.
jlwdvm 11-27-2015 12:13 PM
Thanks. I have the honeycomb style MAF...maybe that is why Texas Speed didn't sound concerned about my placement.
Musclerodz 11-27-2015 02:41 PM
Put it right before the elbow going into the tb. The straighter the airflow is the more stable the a/f wil be.
Ron in SoCal 11-28-2015 02:30 PM
I agree with you Mike. IIRC, GM harness swap instructions say about 6 - 8" downstream of the TB.
