New 13" Wilwood 6 piston C6 Brakes
Item Location (City/State):Kenna,WV
Price:$1,200 plus $75 shipping in Cont. U.S. Description:I have a brand new set of Wilwood front brakes for DSE subframes or any C6 spindles,they were only bolted on my project and never had fluid in or hoses connected to them.I am only selling to go to 14" because of my larger open wheels.http://i1192.photobucket.com/albums/...psdthh7oed.jpg http://i1192.photobucket.com/albums/...psrv68s8ut.jpg |
Is there a wilwood part number associated with this kit?
Can you ship In canada ?
Bump,need to sell,make reasonable offer
Option
If you just want to increase rotor size to 14", it may just make sense to keep the kit you have and just buy new rotors. Then all you need to sell is your 13" rotors.
To do this you just need the (4) longer 3.15" caliper bracket studs (vs. your current 2.5") & the (4) .42" spacers that go onto the studs that space your caliper up correctly over the 14" rotor. Then of course the rotors. I did not see the spacers offered through Summit, but could get from Wilwood. I may have some laying around as well. If I do I will mail to you if you decide to go this route... or I believe a stack of 3/8" AN washers works the same. http://www.summitracing.com/parts/wil-230-9079 http://www.summitracing.com/parts/wil-160-8397-bk http://www.summitracing.com/parts/wil-160-8396-bk Jay |
Same kit
Ya I have the same kit and I can space different rotors from 12.5s up to almost 15" with adding spacers
Cheers Steve |
I just checked my "bone pile". I did not have any of the Wilwood spacers in that size. Again, no real need for the actual "Wilwood spacers", as a stack of washers with the correct i.d. & o.d. is just as effective.
Note: I was incorrect on specifying the use of 3/8" AN washers to do this. I was going off memory, and the AN washers are used along with the 12 point nut to fasten down the caliper. The washers you will need will have the 3/8" i.d. and an o.d. large enough to max out the "seating bore" in the caliper to better help stabilize the caliper. Glad this info helped. From my own experience in past, it was quickly realized that thre is ZERO resale value on aftermarket brake kits. Good luck! Jay Quote:
| All times are GMT -7. The time now is 10:25 PM. |
