1965 Chevelle - Bolt.On.Beast
1 Attachment(s)
Item Location (City/State): Palo Alto, CA
Price: $60K Description:1965 Chevelle Streetfighter Theme I built this car to be a driver both on the street and track. The car has participated in multiple Goodguys Autocross events and American Street Car Series weekends in CA. In 2013 we did the CA to Texas Hall Of Fame Road Tour ~3k miles round trip without issue. Please email: bolt.on.beast at gmail.com for detailed questions or to arrange a showing. Detailed Build Sheet: Suspension: Front: Upper: a-arms - Global West Negative Camber w/ Del-a-lum Bushings Lower: a-arms Stock ( modified to fit RideTech Coilovers with lower T-Bar mount ) Hubs: Kore 3 (black Anodized w/ ARP 1/2”- 20 wheels studs ( reduced length )) Spindles: RideTech 2” Drop Coilovers: RideTech Triples, 5.2” Stroke, 600lb 12” Spring ( double shear design ) Sway Bar: Hellwig 1-15/16” Solid Sway bar Misc: Global West Extended Travel Coilover kit Rear: DSE Swivel Link Control Arms Coilovers: RideTech Triples, 5.2” Stroke, 175lb 12” Spring w/ 1.75 spacer Sway Bar: None Brakes: Front: Calipers: Wilwood W6A with 5.4” piston area Rotors: E-Coated GT72 slotted rotors w/ Dynamic hats Pads: Polymatrix E Misc: Wilwood Caliper bracket machined for clearance to Kore3 C6 spindle bracket Rear: Calipers: Z06 6 Piston (Silver) Rotors: Z06 14” OEM drilled rotors ( modified to fit over axles ) Pads: Hawk HP Parking brake: IPSCO viper spot calipers with custom mounting brackets ( yet to be installed ) Steering: Box: LEE Manufacturing 670 Quick Ratio Box P/S Pump: KRC ( cylinder head mount ) P/S Reservoir: PSC Remote High Pressure Lines: XRP - Black Braided Hoses Wheels / Tires: Front: Wheels: TSW 19 x 10.5”, 5 x 120.65mm Matte Gunmetal Tires: Michelin Pilot Super Sport: 295/30/19 Wheel Spacer: Adaptec Hub Centric spacers 1.75” w/ ARP 1/2”- 20 wheel studs Rear: Wheels: TSW 19 x 10.5”, 5 x 120.65mm Matte Gunmetal Tires: Michelin Pilot Super Sport: 295/30/19 Wheel Spacer: Adaptec Hub Centric spacers 0.875” w/ ARP 1/2”- 20 wheel studs Rearend: GM 12 Bolt ( rebuilt by Meanstreets Performance: San Carlos, CA ) Eaton Tru-Trac / 3:55 gears Moser Axles Misc: Custom hardline to flexible braided brake lines to Z06 calipers Transmission: Viper T56 QuickTime scatter shield ( modified for additional ground clearance ) Driveline: modified stock, shortened and new yoke welded Clutch: McLeod RXT twin disk Flywheel: McLeod aluminum 168 tooth Throwout bearing: McLeod old style hydraulic MGW short throw shifter w/ shifter extension Electrical: Reverse solenoid lockout activation ( wired via momentary switch + brake pedal depression ) Reverse lights wired via transmission pigtail Pedals: Wilwood 6.25:1 reverse mount triple M/C pedal Master Cylinders: Front: Wilwood High Volume 3/4" bore Rear: Wilwood High Volume 7/8" bore Clutch: Wilwood High Volume 3/4" bore Misc: Custom pedal bracket / MC box Wilwood proportioning valve with pressure switch for brake light activation Wilwood in - cockpit brake bias knob ( yet to be installed ) Plumbing: custom bent hardlines Engine: SBC 350, 4 barrel carb, shorty headers Chassis Dyno: Max Power 201.41 / Max Torque 285.27 Interior: Recaro Sport Seats, Wedge Engineering seat brackets Mounted using some existing holes and welded Schroth harness brackets to the floor pan Harness: Schroth 6 point with custom color patches Harness Bar: custom low profile ( Meanstreets Performance: San Carlos, CA ) Sparco steering wheel A/C: Vintage Air ( 3 Knob Backlit Controls / Swivel Ball vents installed directly into the dash ) Custom pulley & tensioner setup for low mount compressor ( left side ) Bracket: Alan Grove low mount compressor bracket Cosmetic Mods: Glass: Dark Window Tint Body Mods: Shaved Drip Rails, Filled Rear decklid seams Fenders: Trimmed lips to 1/2” Brake lights: Dakota Digital LED bulbs |
bumping....
Car is still for sale.
New Price: $45k |
1 Attachment(s)
Still for sale, help me find a good home....
Got any more pictures of the car? got a build thread?
I wish I had been born rich instead of so damn good looking:secret:
| All times are GMT -7. The time now is 07:29 PM. |
