-   -   mucho cars and parts for sale (https://www.lateral-g.net/forums/showthread.php?t=5299)
speedshopmike 07-18-2006 08:08 PM
****stuska engine dyno, complete except cans/adapters, great shape,analog console with gauges including twin egt's, $5000 obo, too big to ship - you can arrange pickup if desired at my shop
****V8 S10 PICKUP
1986 long bed regular cab.
motor: new standard bore 4 bolt main 350, edelbrock rpm alum heads, comp 262/270 extreme hydraulic cam, 1.6 crane roller rockers, comp variable duration lifters, don hardy tri-y headers into nice custom exhaust - 2 into 1 into 2, 3" flowmaster muff with dynomax bullets as resonators, edelbrock stainless tips; has 3" cat converter and race pipe included.
770 holley street avenger, dual plane holley intake, new hei, msd, cockpit timing control knob, taylor 10.9 blue plug wireset, dual remote oil filters plumbed with AN braided steel lines.
less then 5000 miles on whole drivetrain, engine back.
*custom dash with vdo white speedo/tach, autometer phantom oil psi, water, volt, vacuum, air fuel ratio gauges, and clock.
couple are on a-pillar, clock's in glove compartment door.
all factory warning lights replicated, everything works.
water temp gauge not installed presently.
centerforce clutch, new aftermarket (not lt1/ls1) t56 6 speed trans, custom hydraulic clutch linkage, moser axles, 3.73 gears, torsen posi, long race studs.
pro 5.0 shifter, custom stick, leather knob, front/rear shorty consoles
*front/rear suspension techniquies big swaybars, edelbrock shocks, every bushing including body mounts are polygraphite, zq8 steering box, flaming river u jointed steering shaft, tilt column, converted to power windows, locks.
alarm and alpine stereo.
2 inch drop spindles, custom springs.
all interior trim upgraded to syclone style, aftermarket sport buckets, new carpet, fully sound/heat isolated, alpine stero, harwood bolt on (has latch) 'glass cowl hood.
aluminum vette radiator, electric fans with thermostatic adjustable controller.
*weld P9 wheels, 16x9 rear and 16x7 front/275/50 and 245/50 tires; tires all spent
manual flip/remove style sunroof, no leaks.
hi torque starter, ford style remote solenoid.
truck is straight, drives and handles really great.
extremely quick, 23 plus mpg highway .
the bad: needs paint, dings and very minor rust removed, one front wheel is pretzeled but very repairable. has slider rear window that needs replacing. needs throttle cable - it's stretched.
$8000 complete, $6000 less transmission and clutch.
****93 mustang lx 5.0 hatch, stored last 8 years, 46k, reef blue/grey/hatch LX, 5 speed, ati intercooled procharger, new motor, stage 3 tfs heads, e303, aluminum radiator/electric fan, etc etc, 4 wheel disc conversion, koni double adjustable struts, big front bar, mclaren springs, global west trac-link, svo seats, killer alarm, power everything, cold a/c,16x8 roh wheels, 0 miles on new road race radials,frames tied since car was 3 days old,too much more to list, original owner,never wrecked, many spare/upgrade parts included, original owner, steal it for $11,000, this car is not for kids, SERIOUS INQUIRIES ONLY PLEASE
****new tube frame sand-rail chassis:
white powdercoated.
new brembo front disc brake setup,vw engine cradle,front suspension and various other parts included.
$1500
****1985 ninja 900 with 1986 1000 cc motor installed.
all there and straight, bodywork good.
needs tires, battery, chain, a sprocket, brakes bled, clutch hydraulics hooked up.
been stored.
clean title, shop manual, keys included.
$700
****1 set really nice tan sport seats, just like summit/jegs, synthetic leather (nice, actually)
new in boxes, $359 FOR THE PAIR!
****one only black synth leather driver side Monaco seat, like recaro, very very nice, unused but has been installed, with sliders, no shipping,
$545 new, sell for $259
****barely used, very low miles, pro-5.0 shifter for gm t5 camaro and firebird.
no handle, just the shifter.
perfect condition, perfect working order
$159 shipped
****hooker ceramic coated headers for 1st gen SBC camaro
been on my wall as displays
perfect condition
part #2451-1 $299
****new in box grant carbon fiber steering wheel trim ring for 93-97 camaro
****1 flowmaster catback exhaust system part # 17224 for gm trucks
1996 - 1999 Chevrolet / GMC 2500/3500 Truck Siverado/Sierra
3/4 Ton & 1 Ton
5.7L HD & 7.4L
2 & 4 Wheel Drive
Extended Cab / Long Bed CrewCab Dually - 155" & 168" WB
3.00" Outlet
50 Series Big Block Muffler
American Thunder
Single pipe out the Side exit (SOS)
new in box $249
****1984 ford bronco
302/granny-low 4 speed manual-4WD
recent full exhaust, 3" high-flow cat converter, tune up, oil change, rear brakes, master cylinder, lines, starter solenoid and cabling
runs very well, 130k miles, factory gauges incl tach, a/c needs charge
new in box add-aleafs for rear included, has front airbags, HD trailer hitch
white/blue top/blue interior
soft top included - hard to find
new grant steering wheel, high quality coax door speakers,alpine casette stereo (preamp only, no amp installed)
everything works, all electrical good.
has typical bronco rusty wheel lips, tailgate's shot completely, steering's sloppy.
update - i've removed the tailgate entirely and replaced with a bed-net.
glass/motor still good and gate still intact and included in sale.
****one brand new autometer electric, full sweep fuel pressure gauge 0-100 psi
has high and low peak memory function with pushbutton control box
sportcomp = black face, red needle, silver bezel
$199
****one pair 1969 351 windsor heads, nicely done mild porting, with rocker studs $200, no shipping!
****pontiac (BOP) short-tail turbo 400, less then 1k miles on pro-built trans and converter, doug miller unit, ati converter, still in car, hits hard and clean, $800
****T200r4 transmission, dual pattern, with trans specialties 2400 stall converter, has some art carr goodies in trans, needs freshening.
bolt in overdrive in place of your t350!
$400obo
****brand new MAC hi-flow catalytic h-pipe for 94-95 mustang gt
new in box
$349
****eibach 4017140 pro kit spring set, new in box, 92 up honda civic
****msd 8964 knock alert system brand new, no box
****jacobs nitrous mastermind unit, for EEC4 mustangs
****holley oem reproduction musclecar carb, for 1970 camaro z/28, used, off running car, fine shape $300
****bart 15x7 nascar wheels, black, 1 pair only, 5 on 4-3/4, brand new $110/pair, 2 only
****1 pair brand new yokohama avs intermediate tires, 245/45-16, $150/pair, still stickered
****ford 302 shortblock, used core, assembled, non-roller $150/obo
****one old-style vericom 0-60 1/4 mile tc computer
big old-fashioned looking escort radar detect style case
no bracket
power plug could use a re-solder; it's intermittent if you let the cord flop heavily
no bracket
in original box, works fine except as noted above
computes hp, torque, etc
can be mounted on side window for lateral g testing
$89 plus ship
****eibach pro-kit spring set, brand new, part# 3885-140, fits 2000-20005 chevy impala ss and like-bodied cars
****suspension techniques swaybar, #50125, nissan sentra
****unorthodox racing 06054 honda underdrive pulley, new in box
****K&N 57-2507 FIPK kit, new in box
****comp cams/hartman composite valve covers
red small ford
black small chevy
both pairs new in box
****new in box lifters, pre-johnson issues, new old stock:
crane:C37-16, C49, 99377-16 hi-intensity (variable duration)
comp cams: 941-16, 822-16, 812-16, 834-16
crower: 66000-3 small block chevy
****accel igntion box #49327, for 1996-97 LT1 powered vehicles only, new in box
****MAC underdrive pulley, part#4696, 4.6 mod motor mustangs/t-birds, 2 sets, new in box
**MAC underdrive pulley 1990-98 mustang,t-bird, with 3.8 V6
****2 ford motorsport M1007-D178 cobra wheels, 17x8, new in box demos
**muncie trans, 4 speed, with hurst comp plus shifter.
had a recent rebuild before we got it, smooth and quiet, upshifts slick as butter.
does not like to downshift, but downshifts fine with rev-matching, input shaft has a little play
$700obo, no shipping
****richmond gears, new in box, chevy 8.2 10-bolt, 3.55 ratio $229
****precision gears, new in box, 4.56 ratio, dana 44. have install kit for same also.
****precision gears, new in box, gm 10 bolt 8.5 corporate, 3.08 ratio
****eibach 3855-140 spring set, new
**1 pair ws6 trans am snowflake 15x8 wheels with almost new BFG 275/50-15 radial ta's $240
****from 1981 trans am:
both front spindles, complete with all braking parts, including not even broken in EBC greenstuff pads, adn new russell stainless steel DOT legal flex lines, installed same time as the ebc's.
calipers were installed several years ago, but have same mileage as above - car was in storage.
these are the larger big-car calieprs as used on full sized gm cars.
assembles as pulled from car via unbolting balljoints and tie rods.
spindles unboogered and straight/true.
can ship in ultra sturdy boxes as provided by baer with the new stuff.
best offer, will ship, but they're heavy - i paid 90 bucks from arizona to maryland for the new stuff in shipping.
****also new set rear pads for a ws6 disk brake car, 20 bucks plus ship, unused but i lost the box and have brand new ones just in with the new fronts.
after spending an hour looking, i went out and bought some, then 30 minutes later found the ones i already had.
of course.
****1981 TRANS AM oem slap-shifter, cable, related bits, knob, button, etc - still in car, best offer
****81 trans am blue steering wheel, complete with button, mount and stand, good but not perfect
****oem 81 TA front seats; vinyl and lower foams shot; mechanicals/frames/sliders all very good; both sides, best offer
****2 1977-UP SHAKER SCOOPS
also for sale, many speed parts, heavily modified gmc syclone, more, more, more - ask!
Steve68 07-20-2006 03:51 AM
I'm interested in the Bart wheels what style, GM bolt pattern?? 5x4.375
