-   -   Need Opinions (https://www.lateral-g.net/forums/showthread.php?t=5307)
Buick Motorsports 07-19-2006 07:41 AM
Need Opinions
Ok guys... I have the opprotunity to pickup a 69 Camaro rag top for about 22,500us. The car is great shape, save for a couple of small bubbles on the quarters and somme mechanical maintenance. The car has not been butchered at all.
Is this reasonable? I figure it is on the high end, but that I still will not lose any money on the car.
Opinions please!
Streetking 07-19-2006 08:25 AM
Opinions please!
What are the other options on this car, motor size, stick or auto , SS, RS ect.? Make sure you get it on a rack and have it checked out for any rust, check the frame rails ect..
SW
Buick Motorsports 07-19-2006 08:36 AM
It is an SS( I suspect a clone tho). 350/TH350 powertrain with a 12 bolt posi. Rear brakes have been swapped to a disc set up. It has aftermarket wheels, nothing special tho.
A little more info for you.
BC69 07-19-2006 08:52 AM
That is something you really want to find out. Check the cowl tag on that. Also make sure the tag itself wasnt tampered with. But SS or not could make a difference as far as what you are willing too and should pay.
Buick Motorsports 07-19-2006 09:15 AM
What on the cowl tag should I be looking for? I'm a Buick guy!
I know the guy selling it, he's an acquaintance, and he is not holding it up as a guaranteed SS. I just want to be sure that I will get my money out of the car if I have to turn it over for any reason tho I definitely don't plan to.
BC69 07-19-2006 10:09 AM
Go here:
http://www.camaros.org/numbers.shtml#CowlTag
This will help decode it. An SS in 1969 was an X55 code I believe. I also think however that early build 69's did not get X codes? Someone can help me out here. If its original car, the rearend will be a 12bolt on an SS as well.
Hope that helps
Tim
clill 07-19-2006 11:03 PM
SS or not a 69 convert in decent shape for 22K is a very good price.
