-   -   Need a Maxi Fuse block that looks OEM (https://www.lateral-g.net/forums/showthread.php?t=53171)
HellPhish89 06-21-2016 01:21 AM
Been looking and there arent really many choices. The Maxi Fuses will be protecting and supplying power to multiple relays. I want to be able to hard wire them and have a nice clean OEM look. Ideas?
samckitt 06-21-2016 07:38 AM
Blade type that has both terminals at one end, or one with terminal at each end?
Have you checked a junk yard? I few years back I went looking in junk yard for the female terminal to add one to my GMPP LS2 harness fuse box, I had seen a few different blocks on cars that might work for you. Again that was 3 or 4 years ago when I looked.
HellPhish89 06-21-2016 12:55 PM
Essentially I don't want anything like:
http://www.waytekwire.com/images/items/46011fl.gif
GM 12110129 would be great if they werent 60 dollars a piece.
http://www.gmpartsgiant.com/part-pic...5_10_23_RL.png
samckitt 06-21-2016 01:07 PM
Didn't read through all this page, don't know if there is a minimum to buy, but how about $8.75 for one.
http://www.powerandsignal.com/Products/Product/12110129
GriffithMetal 06-21-2016 03:03 PM
http://www.mouser.com/ProductDetail/...2ny30sEFHCY%3d
andrewb70 07-11-2016 08:23 AM
Originally Posted by GriffithMetal (Post 639837)
I assume that the terminals are not included....
Looking at that page I can't quite tell what terminals would be used with that fuse holder. The data sheet was not helpful. Any suggestions?
Andrew
WSSix 07-12-2016 06:09 AM
Andrew,
I did a search for "littlefuse type 2 terminals" and got the following result
http://www.mouser.com/ProductDetail/...gQX32%2fuqA%3d
Doing the same thing using type 8 brought up some results also. I believe either will work for you, but like you, I'm not 100% certain. Might be worth it to contact Mouser. They've been good to deal with in the past in my experience. Good luck!
andrewb70 07-12-2016 06:30 PM
Originally Posted by WSSix (Post 640987)
Andrew,
The type 2 looks like a fine terminal. I will give Mouser a call to confirm. Thank you.
Andrew
andrewb70 07-12-2016 06:33 PM
Also ran across these that look very nice as well.
http://www.mouser.com/Search/Product...fQjyK8zQ%3d%3d
Andrew
HellPhish89 07-12-2016 11:53 PM
It really is slim pickings with oem style Maxi-fuse blocks isnt it?
