-   Lateral-G Sponsor News: Sales, New Product Info (https://www.lateral-g.net/forums/forumdisplay.php?f=43)
-   -   Speedtech releases new stronger Frame Connectors! (https://www.lateral-g.net/forums/showthread.php?t=53179)
Ben@SpeedTech 06-22-2016 03:10 PM
Our new frame connecters for '67-69 Camaro are now in stock and are available to order! These are designed to be stronger than any other design, strengthening the car not only front to back but also side to side. They tie directly into the rear frame rails and the factory bracing for the front subframe, and into the rockers on either side. The center cross member is designed to accept the front pinion mount for those that have our Torque Arm and it doubles as a safety loop too. The smaller sheet metal rails create a protected channel to run your fuel lines and brake cables safely forward. Check out more info here!
http://i1299.photobucket.com/albums/...psb9qjdfh5.jpg
