-   -   2014 Camaro SS Brembo Calipers, Rotos, & Pads (https://www.lateral-g.net/forums/showthread.php?t=53293)
spatel2589 07-14-2016 10:21 AM
Item Location (City/State): Oakland, CA
Price: $800 + shipping obo
Description: Fresh set of front & rear calipers, rotors, and brake pads off of a 2014 Camaro SS.
Front Calipers: 6 piston
Rear Calipers: 4 piston
Rotors: 14" rotors with oversized lug holes
Less than 5,000 miles on set, very good condition. I was going to install these on my 68 camaro but decided to go another route.
http://i455.photobucket.com/albums/q...o%20Brakes.jpg
:animated_bye_bye_em
tpichevy 07-16-2016 05:19 PM
How could I run these on my 70 camaro? I already have 4 disk brakes buy bigger is better
RyanB88 07-16-2016 05:40 PM
I'm actually running the same setup front and rear on my 69 Camaro.
I had to use a Baer backing plate and an oversized parking shoe to get the parking brake to work. But This setup is the best bang for the buck that I have found! Its been working awesome on my car.
Corey R. 07-19-2016 10:45 AM
What did you do for front hubs?
RyanB88 07-19-2016 01:57 PM
I used the stock drum brake hubs (actually the Kore 3 aluminum hubs, but the stock drum brake hubs work too). For the caliper brackets, I used LS1 Camaro conversion brackets and drilled out the holes since the Brembo caliper bolts are larger diameter.
I believe I did have the center hole of the front rotors honed out by a machine shop. But that was pretty simple and only cost about $50.
spatel2589 07-29-2016 06:49 PM
:bump: $750 + shipping
Trans am sim 08-07-2016 07:17 AM
Brembo brakes
Hi my name is sim I'll buy them if I can make them fit a 70 Trans am 727-851-2787 I'll buy them today if that's the case
spatel2589 08-12-2016 10:05 AM
bump
spatel2589 09-22-2016 04:44 PM
:bump: $600 come take these
tpichevy 09-22-2016 05:02 PM
Any idea if these will fit behind a 17" wheel?
