2nd Gen F-body Spectra LS swap fuel tank and Corvette regulator
Item Location (City/State): Chicago, Il
Price: $225 Description: 2nd Gen F-body Spectra LS swap fuel tank and Corvette regulator 2nd gen F-body. GM 42 BFI Spectra Premium tank for EFI swap. Purchased 08/2014. Corvette regulator for LS swap. Used for about 1600 miles. I believe it only fits 70-73, but you can double check. Pick up only near 13000 S Torrence Ave Chicago 60633. |
Fuel Tank
What size are the supply and return lines
I actually have a carbed car 980-1150 cfm that I run a return line thru a regular and A-1000 external pump... Bob |
I bought AN fittings in a kit with the regulator. The actual lines from the tank are whatever was stock for a 1971. I can double check them if you'd like. The pump that it came with worked fine on my LS car.
Is this tank used? Why are you not using it? Is this the 2nt gen tank with better baffles? Can I see pics please? Looking for LS swap parts and this is a start! Thanks
It was used for 1600 miles as stated above. I have no idea what's inside. I took it out of the box and put it on the car. It may have baffles, but I don't know. I went a different route. I will post pics either later today or tomorrow.
http://img.photobucket.com/albums/v2...4/IMG_1527.jpg
This is a pic from when I first got it. I will get a current pic as soon as I get a chance. Worked all yesterday and will be doing it again today. |
tank
Im interested in your tank,so the pump is in the tank? and I live in green bay area would you be able to mmet
The pump is in the tank. Sorry, pick up only.
If we can ship, I may be able to make this disappear.
Wish I could. Sorry.
| All times are GMT -7. The time now is 10:33 AM. |
