LS3 Intake manifold setup takeoff w/ injectors, rails, etc
10 Attachment(s)
Item Location (City/State):Las Vegas, NV 89131
Price: $425 SOLD!! Description: I have a low mileage take off (8k) LS3 intake manifold setup comes complete with: -intake manifold -manifold & TB seals - GM MAP sensor and hold down screw -GM fuel rail assembly w/ hold down bolts -GM LS3 / LS7 42# fuel injectors w/ retaining clips -upper intake manifold beauty cover ( some refinish them for custom look , see carbon fiber pic as example) fits all LS / Vortec engines with rectangle ports cylinder heads (ie L76, L92, LY6, L99 , etc) Complete intake manifold assembly as listed above $425 + shipping SOLD!! I do also have a new LS3 (gold blade) take off DBW throttle body available for a extra cost pm/call/ text (702)677-4085 |
Will this bolt onto a 2009 6.0 Yukon ls2? I'm new to the LS motor so I have lots to learn.
This is for rectangle port heads Look for 3 digit cast # on corner of heads , near valve cover (ie 317, 799, 821, 823, etc. ) They never put a "LS2" in a Yukon, you may have a 6.0L, but not a true LS2 Thanks Jeff |
It's a 6.0 aluminum block with 243 heads .....been told it's the same as a ls2...is that wrong?looking to do a ls swap in my 1970 camaro
Not necessarily similar to the L92/ L99 vs LS3 same displacement, but many differences between them the "243" heads are cathedral port, so the LS3 intake will not work for your engine |
Intake manifold setup & TB are SOLD!!
| All times are GMT -7. The time now is 01:45 AM. |
