-   -   DSE Super Tank 1000 - 1969 Camaro (https://www.lateral-g.net/forums/showthread.php?t=54299)
l2azorback 01-13-2017 06:03 AM
Item Location (City/State): Red Bud, IL
Price:$old Shipped CONUS
Payment Options: PayPal +4%, or Direct Bill from V8SR, Kelle can send an invoice to you so you can use your Credit/Debit/Checking Account.
Description: Hello, I have a gently used ~350 miles DSE Super Tank 1000 Stainless Steel fuel tank that has been narrowed for the 1969 Camaro, works with DSE mini tubs, and has notched corners for exhaust clearance. This set-up is designed to support up to 960hp NA. I changed directions with my build, and am no longer in need of this set-up.
DSE Website info:
1000 Series Standard:
• Dual 190Ltr/Hr Pumps
• Same Basic dimensions as 5th Gen module
• VaporWorx Pulse Width Modulation (PWM) Kit Required
• 19 Amp Draw
• 80.3 GPH @ 60psi
• 960HP Normally Aspirated
• 800HP Supercharged
Tank does NOT come with a fuel pump or PWM controller, as I am using them in my new set-up, thus the price adjustment, as these are over $2700.00 new, plus shipping. This tank still has the pick-ups in the corners and associated internal plumbing to include the sending unit that came with the tank. A new CTSV fuel pump is $495.00, and the Vaporworx PWM fuel pump controller is $525.00. You can have this awesome returnless set-up for much less than what I paid new. I was feeding a Scott Shafiroff 540 Ultra Street BBC with Holley HP MPI with absolutely no issues.
Regards,
Larry
http://i190.photobucket.com/albums/z...psdt2ydvbq.jpg
l2azorback 01-21-2017 06:35 AM
Bump....
Bonebuster29 01-23-2017 09:44 AM
if only it was for a 67/68...
Zl1427 01-24-2017 03:46 PM
Will this work with DSE Mini tubs?
l2azorback 01-26-2017 07:01 PM
Yes,
This tank works with DSE Mini Tubs. My car has DSE mini tubs.
Regards,
Larry
l2azorback 02-01-2017 10:45 AM
Price drop $1000.00 Shipped
aany001 02-02-2017 10:39 AM
Sent a PM
l2azorback 02-18-2017 08:35 AM
Bump...price drop....$950.00 shipped
aany001 02-24-2017 03:24 PM
Larry I sent you a PM.
Steve
l2azorback 03-25-2017 08:24 AM
Bump...last price drop
