L76 6.0L aluminum block complete engine
6 Attachment(s)
Item Location (City/State):Las Vegas
Price: 5700 Description: A buddy (Curtis) has decided to go to a stroker engine for his 67' Camaro build that I am helping with So we are listing his engine for sale, never put in car, still fresh on stand We sourced a low mileage pullout 08' L76 6.0L from a G8 ( aluminum block 6.0L w/ "LS3" style rectangle port cylinder heads) I broke it down and went through the complete engine machine work was handled locally by my trusted shop Rick @ HBR Competition Engines removed the VVT/AFM setup and -std bore, polish crank -new rings, main, rod & cam bearings -Melling #10295 high pressure oil pump -new LS2 HD timing set and damper -new GM gaskets, seals, LS2 timing cover kit, LS3 valley cover -LS7 lifter set w/ LS2 trays - EPS cam 226/234 598/601 113+2 LSA cam -Comp Cams 7.425" .080 hardened pushrods -GM #823 rectangle port cylinder heads, milled, comp valve job, PRC .650" dual valve springs w/ titanium retainers, "LS3" rocker set w/ Comp Cams trunion upgrade kit installed -ARP fasteners (Heads, cam, balancer, flywheel & PP) - new LS3 intake manifold assembly w/ fuel rails,LS3/7 42# injectors & map sensor - new LS2 "silver blade" dbw 90mm throttle body - knock sensors, cam & crank sensors - black powder coated valve covers w/ SS allen socket head hardware -LS2/3/7 coil packs, harnesses & brackets, spark plug wire set -new Corvette C6 harmonic balancer w ARP bolt - C6 Corvette LS2/3 low profile oil pan kit w/ dipstick & tube doesn't include front accessory drive in Las Vegas, NV at Curtis' house Asking $5700 obo as pictured pm/ call/ text Jeff (702)677-4085 or Curtis (702)610-3388 |
Nicely done, and priced to sell!
SOLD
:thumbsup: |
| All times are GMT -7. The time now is 11:22 AM. |
