Hurst Driveline Conversions Crossmember Kits for 64-66 Mustang w/AOD or Tremec T5
If you plan on installing an AOD automatic or Tremec T5 manual transmission into your 1964-1966 Ford Mustang, Hurst Driveline Conversions now offers bolt-in solutions that will simplify your conversion.
Part # 67530002 Hurst Driveline Conversions Crossmember Kit for the 1964-1966 Ford Mustang with an AOD automatic transmission https://c1.staticflickr.com/3/2873/3...d57d1100_b.jpg Description: This custom built bolt-in crossmember kit is specifically designed for properly installing a Ford AOD automatic transmission in all 1964-1966 Mustangs. This crossmember also features a provision to retain the factory parking brake function. Manufactured in the USA from heavy gauge steel and has a black powder coated finish for long lasting durability. Kit includes crossmember and mounting hardware. Part # 67530003 Hurst Driveline Conversions Crossmember Kit for the 1964-1966 Ford Mustang with a Tremec T5 manual transmission https://c1.staticflickr.com/1/775/32...637a8c23_z.jpg Description: This is a custom built bolt-in crossmember kit and is specifically designed for properly installing a Tremec T5 manual transmission in all 1964-1966 Ford Mustangs. The crossmember also features a provision to retain the factory parking brake function. Manufactured in the USA from heavy gauge steel and has a black powder coated finish for long lasting durability. Kit includes crossmember and mounting hardware. Please call 707-544-4761 or visit www.Hurst-Drivelines.com for additional application and product information. |
| All times are GMT -7. The time now is 02:36 PM. |
