-   Lateral-G Sponsor News: Sales, New Product Info (https://www.lateral-g.net/forums/forumdisplay.php?f=43)
-   -   MillerBuilt's WELD-ON C6/7 Hybrid Floater System (https://www.lateral-g.net/forums/showthread.php?t=55030)
MillerBuilt 03-07-2016 08:06 PM
C6/C7 Hybrid Floater System -
These NEW billet steel Adaptors Weld-On to nearly any axle tube!
Advantages:
  • Welds to your new OR existing housing
  • Reduces/eliminates brake “knockback”
  • Eliminates axle deflection
  • Wheel & tire remains intact should an axle failure occur
  • Front or Rear Caliper / E-Brake Cable Positions
  • Utilizes the robust, zero maintenance C6/C7 ZO6 Hub Bearing Unit
  • Utilizes OEM C5/C6/C7 Corvette, and 5th Gen Camaro brake kits
  • Utilizes aftermarket C5/C6/C7 Corvette, and 5th Gen Camaro brake kits
  • Utilizes your existing BAER / WILWOOD caliper & rotor (some restrictions apply)
  • Super compact design compared to traditional style full floaters
  • All advantages of a traditional style full floater without the maintenance
  • Replacement parts available at local GM dealer or local parts house
  • No modifications required to the hub bearing unit as other kits in the marketplace
Fitment: Any rear-end with 2.750”-3.250” o.d. axle tubes
See information listed below for both the "long" and "short" versions...
Weld-On “Short" Base Kit (pictured below)
http://i35.photobucket.com/albums/d1...psxrevc6bp.jpg
Weld-On “Short" Base Kit (pictured above)
Base Kit (Short) Includes:
• (2) Billet Steel, Short Hybrid Floater Adaptors
• (2) Billet Aluminum Caliper Brackets
• (2) C7 Corvette, SKF 33 Spline Hub Assemblies
• (1) Install Kit
• (2) Hub Spacers
• (2) Billet Aluminum Hub Cap Seals
________________________________________
STARTING AT - $1,398.00
Base Kit (Long) Includes:
• (2) Billet Steel, Long Hybrid Floater Adaptors
• (1) Install Kit
• (2) Hub Spacers
STARTING AT - $1,498.00
Add Axles - $400.00
• (2) Hy-Tuf Full Float Axles
Add E-Brake items - $325.00
• (2) C5/C6 Corvette Complete E-brake Assemblies
• (2) C5/C6 Corvette Parking/E-brake Cable Brackets
Have interest?
Have questions?
Need more info?
Distributor Inquires Welcome!
To help determine which kit might work best for your particular application, please see below picture.
http://i35.photobucket.com/albums/d1...psi1qfyc6n.jpg
Questions welcomed!
MillerBuilt 08-06-2016 10:53 AM
FREE Shipping & PayPal This Weekend!!
FREE Shipping & PayPal This Weekend!! (8/6/16 & 8/7/16 - "lower 48" states only)
MillerBuilt 10-01-2016 02:43 PM
October Special!
FREE Shipping & PayPal through October!! ("lower 48" only)
Advantages:
• (1) Install Kit
• (2) Hub Spacers
• (1) Install Kit
• (2) Hub Spacers
Add Axles - $400.00
Have interest?
Have questions?
Need more info?
Questions welcomed!
MillerBuilt 10-06-2016 08:16 PM
This........ (floater ends)
http://i35.photobucket.com/albums/d1...psainamkh2.jpg
Gets you to this..... (complete hybrid full floater system)
http://i35.photobucket.com/albums/d1...psh2bmigjf.jpg
http://i35.photobucket.com/albums/d1...pse5lmj6be.jpg
http://i35.photobucket.com/albums/d1...ps1onf1adn.jpg
Housings can be supplied as well for a complete solution......
Thanks for looking!
MillerBuilt 10-19-2016 06:41 AM
Advantages:
• (1) Install Kit
• (2) Hub Spacers
• (1) Install Kit
• (2) Hub Spacers
Add Axles - $400.00
Have interest?
Have questions?
Need more info?
Questions welcomed!
Thanks for looking!
In Stock!
MillerBuilt 02-09-2017 06:49 PM
Advantages:
• (1) Install Kit
• (2) Hub Spacers
• (1) Install Kit
• (2) Hub Spacers
Add Axles - $400.00
Have interest?
Have questions?
Need more info?
Questions welcomed!
Thanks for looking!
In Stock!
MillerBuilt 06-05-2017 06:18 PM
In Stock
In Stock
