-   Speedtech Performance USA (https://www.lateral-g.net/forums/forumdisplay.php?f=90)
-   -   A Body ExtReme Frame Photos (https://www.lateral-g.net/forums/showthread.php?t=55038)
Ben@SpeedTech 06-08-2017 11:00 AM
Some pics of our 68-72 A-Body chassis and exhaust detail, front suspension here. Note things like the tie down hooks for trailering and splined sway bars are standard on ExtReme frames. This customer chose to run 295-30-19s up front, although the suspension is designed to accept 315s. Everything about this frame is designed to be the missing link between street cruiser and race track thrasher. One thing that's cool that we don't often consider is the inclination angle on the front shocks is more effective allowing for a lighter rate spring to achieve heavier rate handling characteristics. Headers are designed to play nice with this super low stance. The spindle was redesigned to have even better geometry for even better handling than our current AFX spindle. Any questions or comments feel free to post 'em up!
http://i1299.photobucket.com/albums/...ps9zfzdmov.jpg
http://i1299.photobucket.com/albums/...psupapcxto.jpg
http://i1299.photobucket.com/albums/...psbvqlamw3.jpg
http://i1299.photobucket.com/albums/...psrnylxd62.jpg
http://i1299.photobucket.com/albums/...psot1782vl.jpg
http://i1299.photobucket.com/albums/...psv83rgigf.jpg
Ben@SpeedTech 06-08-2017 11:01 AM
Mid section here. This car sports 3" exhaust that tucks nicely parallel to the Torque Arm. We considered a triangulated 4 link for the A body cars when this chassis was in development mostly because that's what everyone was used to. That idea quickly got axed to run our Torque Arm instead, there's so many advantages to this system it just didn't make sense to run a 4 link. If you've never experienced how smooth and predictable our torque arm is, next time you're at an event ask a Speedtech equipped car's owner for a ride along.
http://i1299.photobucket.com/albums/...ps6ihrd2fq.jpg
http://i1299.photobucket.com/albums/...psvwaqfozf.jpg
http://i1299.photobucket.com/albums/...ps9p8y6jj1.jpg
Ben@SpeedTech 06-08-2017 11:05 AM
Rear suspension. One of the biggest challenges with any lowered Pro Touring car is exhaust clearance, some rear suspensions make it more difficult than others. Our Torque Arm with it's panhard bar is tight too, but still allows ample room for a 3" system. We don't have a specific exhaust kit available, we usually buy a SW mandrel bent stainless universal builder kit and custom fit it to the car. Dutchman preps our 9" axles including welding on all Torque Arm brackets.
Unique to Speedtech are our 2-peice "Articulink" lower trailing arms that use components machined from billet steel to allow the arms to rotate with suspension articulation. This really makes for smooth transitions as you throw the car back and forth in the curves and over bumps in the road. Note that the arms have multiple mount position options as do the shocks so that you can maximize performance with your desired ride height. That billet lower shock mount can be flipped for a 1 1/2" difference in ride height without adjusting the shock at all. This suspension works so well a rear sway bar isn't typically necessary unless you're running a LARGE front sway bar for racing and the rear bar is needed to balance and reduce understeer. We like to use Rick's Tanks for our builds, they come with the extra clearance of notched corners and pretty much any fuel pump requirement provisions.
http://i1299.photobucket.com/albums/...pscrjwjdqq.jpg
http://i1299.photobucket.com/albums/...ps1lgyil3b.jpg
http://i1299.photobucket.com/albums/...psm48o3pi7.jpg
http://i1299.photobucket.com/albums/...psggl7tmqe.jpg
http://i1299.photobucket.com/albums/...psfr8qlppm.jpg
http://i1299.photobucket.com/albums/...pszrvlbwwe.jpg
http://i1299.photobucket.com/albums/...psh1bmeyey.jpg
http://i1299.photobucket.com/albums/...psx8hiplg6.jpg
Ben@SpeedTech 06-08-2017 11:09 AM
Here's the whole frame, each one is customized to the owner's needs and driving style. Click here for details on the features and benefits of buying the ExtReme over competitors.
http://i1299.photobucket.com/albums/...psjv8ky31h.jpg
jeff71 06-08-2017 11:41 PM
Can you post a pic of the car on the ground to see ride height.
Ben@SpeedTech 06-13-2017 09:39 PM
Yep, we plan to do a little photo shoot outside in a few days, I'll be sure to put some pics up here.
