-   -   Aftermarket C6 Front Suspension components (https://www.lateral-g.net/forums/showthread.php?t=55246)
Jtomas801 07-22-2017 09:36 PM
Item Location (City/State):
Covina, CA
Price:
$40 - $650
Description:
I am selling off most of my C6 front suspension stuff, going a different route because of the issues I have found with my frame. This would make a great setup if someone is buying a bare c6 front frame and need the components for it.
The GMR C6 front hubs. Includes brake rotor adapters, 8 on 7", for The Brake Man (TBM Brakes) 13" rotors or others and includes the socket to replace and repack the bearings. They have 1/2" studs set up on a 5 on 4.75" bolt pattern. Rotor adapters are still available for Wilwood and Baer brakes. $650 obo.
https://farm5.staticflickr.com/4321/...e40bb1e3_c.jpg20170722_173233 by Jonathan Feltis, on Flickr
C6 Corvette uprights, new just mocked up on car. The steering arms have been cut off. SOLD
https://farm5.staticflickr.com/4294/...87e4ab4e_c.jpg20170722_174309 by Jonathan Feltis, on Flickr
AGR performance power steering rack. Part#712581, Never used, just mocked up. Slight surface rust on some of the hardlines as seen in the pictures. includes tie rod ends. SOLD
https://farm5.staticflickr.com/4306/...50abc9cb_c.jpg20170722_180526 by Jonathan Feltis, on Flickr
Speedway Engineering 3 piece sway bar 1-1/4" x 32", with steel arms, bushings and hardware. SOLD
https://farm5.staticflickr.com/4306/...1862260a_c.jpg20170722_183644 by Jonathan Feltis, on Flickr
Chassis Works shock mounts. $45 obo.
https://farm5.staticflickr.com/4315/...ddcb3563_c.jpg20170722_192450 by Jonathan Feltis, on Flickr
Aurora rod ends, 3/4" x 3/4". There are 5 AM12T right hand and 5 AB12T left hand. Teflon lined. $40 Ea obo
https://farm5.staticflickr.com/4306/...4d94ea5e_c.jpg20170722_184538 by Jonathan Feltis, on Flickr
ARP wheel studs, Part #ARP-100-7705, 2 packs of 5. $10 Ea.
https://farm5.staticflickr.com/4307/...9d85bd46_c.jpg20170722_181857 by Jonathan Feltis, on Flickr
Thanks,
Jon
Jtomas801 07-26-2017 07:01 PM
The C6 arms have been sold.
Thanks,
Jon
Jtomas801 08-01-2017 08:17 PM
Lowered prices, open to offers.
Thanks,
Jon
232_ray 08-01-2017 11:31 PM
GMR hubs? Any chance u got a link for those things. I'd like to do I little research on them. Thanks.
Jtomas801 08-02-2017 12:07 AM
Hi there,
From the looks of it they are no longer making these, but here is some links with information on them:
https://youtu.be/LfIOdK2vhlY
https://lateral-g.net/forums/showthread.php4?t=40990
They are really nice pieces and are rebuildable with standard size bearings, Inner bearing: LM300849, Outer bearing: L44649, Both "Timken".
Also included a trick socket to remove the bearings. If the brakeman rotor adapters don't work for you, there are adapters for Wilwood and Baer available from the person I purchased these hubs from.
Let me know if you have any other questions.
Thanks,
Jon
Jtomas801 08-14-2017 07:45 PM
Bump, adjusted prices.
Thanks,
Jon
Jtomas801 09-08-2017 09:18 PM
Back to the top.
Thanks for looking,
Jon
Jtomas801 12-04-2017 05:18 PM
Lowered prices.
Thanks,
Jon
aany001 12-09-2017 10:49 AM
Jon can the rotor flanges be removed to run a factory C6 rotor?
Jtomas801 12-09-2017 07:25 PM
Yes the rotor adapter can be removed and/or be replaced with another adapter for other rotor bolt patterns. I believe it can be but, it would not be simple. It would add track width to each side, the wheel studs would be short and you would need to shim the caliper to match the rotor. I will pm you a link with some info on it. It would probably be cheaper/easier if you went to a two piece rotor with the correct rotor adapter.
Thanks,
Jon
