LS swap 69 Camaro w a 1990 (metric) PS Box
How did you guys run your power steering hoses ?? I have a 69 Camaro with the complete Holley LS swap kit. I was just looking for ideas. AN fittings, no AN fittings, routing etc ...Thx.
I had a shop make the pressure line, and there is an inexpensive return hose with good length made in the aftermarket. One end threads right in the box, and cut to length with a clamp on the reservoir side. I'll get you that part number in a bit.
AN adapter fittings at the box and use ptfe lines.
Thanks for the replies guys. I'm not sold on the AN fittings for power steering. I would prefer custom bent tube ends like OEM. I'm using a metric box and they don't have leak issues with stock fittings.
| All times are GMT -7. The time now is 10:43 AM. |
