Turbo/Blower ready 406cid SB Chevy -- 0mi.
Item Location (City/State):Yuba City, CA 95991
Price:$7500 Description: Very nice build, 0 miles! Built to handle 1,000+HP (CSU Carbs Blow-thru carb' and stainless "up-n-forward" headers available separately) *World Products Motown 1 Block, ARP MSK kit upgrade *Scat Pro series E4340 steel crankshaft, 3.75", Nitrided *Scat Pro series E4340 H-beam rods, 5.85" length, Manley bushings, Oliver WSB/ARP L-19 bolts *Diamond 2618 forged aluminum pistons, built for forced induction/pump gas *Speed-Pro Hellfire ring set *Stef's oil pan/pickup, Milodon +10% oil pump *ARP Pro Series head studs, 12pt. stainless steel nut upgrade *SCE Titan ICS head gaskets *Brodix 10X RI Raised Runner "23 degree" castings, full CNC porting (flow like 18* heads!!) porting, Ferrea Super Alloy 2.15"/1.60" valves, Comp, PAC valvetrain, 334cfm @.600", fresh from Terrill's Alum. Heads - Chico, CA *Jesel Pro Series shaft setup, 1.55/1.60, ARP hardware upgrade at all fastener locations, includes more than a half-set of rockers/shafts/adjusters/wheels/etc. as roadside service extras *Custom Kenny Duttweiler turbo solid roller, Comp lobes, 236*/242*, ~.600" lift *Comp Cams 894 offset lifters, fresh from Comp (with receipt) *Comp Cams 7100 billet timing set, 2-piece billet aluminum timing cover *Innovators West damper, steel hub *CSR electric water pump *GM Performance "valvetrain oiling" valve covers, great option for those that actually drive their ****, keeps the springs muy happy *Brodix HVH #1007 manifold, brand new virgin, unported *ARP hardware just about everywhere/anywhere *Machining, balancing, clearance checking by Rex Hutchison Racing Engines, Sacramento, CA *$7,500 (intake-to-pan) ~540HP/500ft.-lb. naturally-aspirated pretty easily, solid 11's in the 1/4mi. Apparently Photobucket ain't what it used to be, so please text for much better pictures. Please feel free to check us out on evil Facebook and Instagram for previous engine build customers. We do very OCD-clean, precision engine work. Thank you! Temio Williams Outlaw Performance 301 Burns Drive, #C-2 Yuba City, CA 95991 (530) 751-3966 --- shop (530) 237-7065 --- cell |
Imgur works as well as photobucket used to.....give it a try
I thought it was a typo' when Photobucket said it was "only $399.95/year". Just silly. More pic's ASAP! |
SALE PENDING, as of 8:00 A.M., P.S.T. tomorrow morning. Merry Christmas!
| All times are GMT -7. The time now is 12:00 AM. |
