-   LSX Conversions (https://www.lateral-g.net/forums/forumdisplay.php?f=70)
-   -   Drilling heater ports on water pump (https://www.lateral-g.net/forums/showthread.php?t=55954)
waynieZ 12-21-2017 05:20 PM
Tapping heater ports on water pump
Hi I have my FEAD on my motor already and I am thinking of tapping the Heater ports on the water pump for AN fittings. If I use grease on the tap to catch the chips will I be OK doing it on the motor? I need opinions please.
If I don't do it on the motor i will have to figure a different way to connect the hoses.
dontlifttoshift 12-22-2017 05:26 AM
Pull the thermostat off and put a shop vac in the hole where it was.
You don't have to drill, only tap, the holes are already the right size.
waynieZ 12-22-2017 08:48 PM
That's what I was thinking, but wasn't sure. Thanks!
