Circle d converter (4l80e turbo)
Item Location (City/State):Bay Area Califonia
Price:800 Description:Cost New is $978 only has dyno time and a trip or two around my neighborhood.. I went with a magnum t56 and won't need this anymore $800 shipped 258mm single disk with lock up pro series II 3600 stall loose down low for spool up 4l80 flywheel bolt pattern |
Circle D converter
Is this manufactured by Circle D Specialties, do you have a part number, what size motor (cubic inches) was it spec'd for, and does it use a stock 4L80E flat flexplate or a dish style 5.3 design? Thanks
Yes I bought it from circle d specialties
I had it spec’d for a 4.8 with a triple 12 cam and 76mm turbo It used a stock truck 4l80e flywheel Works perfect but I didn’t like automatic so I installed a magnum t56 |
Up we go
| All times are GMT -7. The time now is 03:02 PM. |
