-   Transmission and Rear End (https://www.lateral-g.net/forums/forumdisplay.php?f=39)
-   -   T56 wiring connector question (https://www.lateral-g.net/forums/showthread.php?t=57221)
Timberline 12-23-2018 04:02 PM
1 Attachment(s)
Hi all, need some help with a part number.
In the pic it shows the male connector in Blue and having trouble finding the female anyone know the part name and number?
As you can see the female in yellow that I have is different narrower pin configuration.
Gmachine1911 12-23-2018 09:45 PM
1 Attachment(s)
If that's the Vehicle Speed Sensor, you need pigtail pn: PG-096 from Ron Francis (about $8 from Summit). I made the same mistake when doing mine...
Timberline 12-24-2018 07:26 AM
Thanks gmacine1911 !! it is the speed sensor 😀
Chevy Kid 12-24-2018 12:02 PM
FYI that is a ford speed sensor connection used in most 90’s and up manual transmissions. Good find a Summit!
