LS7 Clutch decision/advice
Looking for advice on a clutch kit including flywheel recommendations for a mild/moderate modified LS7 in a 1st gen Camaro, 570 crank HP 530 tq. 90% street 10% road race
Is a DYAD or Manic 9000 overkill? |
Same... I'd use the stock LS7 clutch/fly.
We sell for $550 shipped with the OEM bolts if you don't have one already. -Dale |
Keeping with the current theme, if you need a slight upgrade with excellent pedal look at the ZR1 clutch . Factory rated for at least 640 hp
Price is one thing and performance and feel another. I've experienced driving the LS7 in a '15 Z/28 and my experience was the clutch engagement point. It's too far out on the pedal stroke. Apparently Ram makes a "hydraulic bearing pedal adjuster" which from my understanding works as an accumulator to adjust pedal engagement position. Wondering if pedal engagement is different with the LS9, DYAD or Mantic clutches Please let me know you experiences Thanks Dave |
I've been very happy with my Monster LT1-S dual-disk clutch. Monster uses the LT1 dual disc pressure plate and discs from the LT1 engines and makes their own flywheel to mount it to the LS engines. You can have them lighten the flywheel if you like but I did not do so.
It is a very nice setup to drive, basically feels just like driving a clutch on a new car (since it's the same parts). I have about 5k miles on it now with no complaints. It's not going to be the cheapest setup out there, but if you search around, they do have some vendors that sell at lower prices than buying from them direct. That is what I did... |
[B] Thanks again, Dave |
As for release point, I think that has a lot to do with hydraulics as well as the clutch. On mine, it releases / engages just below the middle of travel, which feels very correct to me. It's certainly not high, and not grabby off the floor. It feels very smooth... |
| All times are GMT -7. The time now is 02:23 AM. |
