Need some help with my 69 camaro
Not sure what's going on but i just discovered that when I put the key in the lock position my radio still has power. I replaced the key assembly and the old one was so worn that the key would pull out when it wasn't in the lock position so i didnt discover the issue until now. Anyway, I appreciate any help the forum can offer.
Thanks in advance |
Maybe in replacing the lock assembly, the switch is now slightly out of adjustment. So the switch is partially in the accessory position when the key is in the off position.
The remedy is to loosen the 2 bolts holding the switch to the column, and sliding the switch so it's detents are in the off position while the key is in the off position. I think you can do this by removing the key to ensure the lock is in the off position. Hope that helps. |
Yup that did it. Thanks!
| All times are GMT -7. The time now is 08:14 AM. |
