-   Engine (https://www.lateral-g.net/forums/forumdisplay.php?f=37)
-   -   Took my engine apart. Is this a Crack? (https://www.lateral-g.net/forums/showthread.php?t=5940)
GvEman 09-14-2006 01:51 PM
I started a couple of weeks ago with ripping the old tiered engine out of the car and I started to pick it apart. Yester day I took the pistons out of the block and I found out it was about time. The timing chain for example was so slack so you could almost pull it of the wheels!! :willy: Is that good?
And when I lifted the crank out I found this.
http://img226.imageshack.us/my.php?image=sprickamp9.gif
Looks like some kind of casting fault but I don’t know if its critical.
I did also notice that the bearings was quite worn out.. The crank bearing in front of the engine was quite good but as I got further back they got worse and worse. Bad crank?
Just some pictures of the other parts...
http://img231.imageshack.us/my.php?image=engine1ua7.gif
http://img231.imageshack.us/my.php?image=engine2rl2.gif
http://img226.imageshack.us/my.php?image=engine3ql4.gif
So what do you say? Do i need to buy another block or another engine?
Cheers
zbugger 09-14-2006 02:51 PM
What does the other side of that look like? The cast finish side.
markus 09-17-2006 08:43 AM
it doesnt look like a crack. Ive seen a lot of that with different blocks. it looks to be a casting flaw, if you question it take it in to get it checked for cracks.
3kidsnotime 09-17-2006 04:18 PM
It does not look like a crack to me, Just a casting flaw,But you will never know till you mag it, But it also is in a non fluid area and we usually grind that area out for long rod and stroke, Also we cut a radius in that area as well to keep from cutting on the piston skirts.
GvEman 09-18-2006 01:24 PM
Okay thanks for your opinions, i did have a closer look at the back side (the casting side) and it looks like a casting flaw a nasty one but it dosent look like a crack, but as you say you never know. Do you guys think that its worth building on this block or shall i buy something else. Have been thinking about LT1 but i dont know.. sounds like a load of work. But on the other hand its fun to build and it gives me more posibillities in the future.
Give me your 2 cents.
