Ignition combo
First off i have a 70 Mustang. 351C 2V bored .040 over, edelbrock heads, intake, Lunati 505 lift cam, 750 Demon, and for the ignition a MSD 6 AL box with an Accel billet dist. and MSD Blast 2 coil. I'm curious to know how well the two will mesh together. and how adjustable they are to match each other. should i lose the dist. and just go MSD all round or not. ????? need some help
That's a fine setup. All the parts are compatible and should provide more spark energy than you'll ever need. I'd even recommend opening up the gap in the plugs because you'll have no problem firing them. A bigger gap means a bigger, broader spark, and that can help everything from idle to peak power. ~SP~ |
| All times are GMT -7. The time now is 09:25 AM. |
