-   Wanted/WTB (https://www.lateral-g.net/forums/forumdisplay.php?f=46)
-   -   Welder (https://www.lateral-g.net/forums/showthread.php?t=6888)
jsconiers 11-24-2006 10:36 AM
Welder
Any welding shop able to weld a sump to a factory 1st gen tank? It will be a brand new tank.
Rick D 11-24-2006 01:00 PM
Where are located at?? I'm in IL northwest burbs. Can do it for you. Just did one on a 68 Chevelle.
jsconiers 11-24-2006 02:15 PM
I'm located in Melrose Park, IL. What would you charge? How would
I get the tank to you and get it back?
I'd like to run something similar to the following for an ls1 swap:
http://www.ls1tech.com/forums/showthread.php?t=472609
There look to be two ways....one would be welding in a sump to the factory first gen tank, the other would be welding an intank pump setup into the tank. I would prefer the first if possible. I can be emailed at jsconiers(at)comcast(dot)net
JOHN
Rick D 11-27-2006 07:10 PM
E Mail me with a contact #
