Fuel Lines?
I am building a '69 Camaro and it's a custom build. We are ready to run fuel lines. We are thinking of running 1/2 inch braided steele fuel line from the tank all the way up to the mechanical fuel pump. I have been told that I don't want to do that, but if I am going to, I should use teflon inner coated braided fuel line. Apparently the teflon tubing prevents the fuel from permeating through the rubber tubing.
I realize I should run as much hard line as I can because the rubber tubing simply won't last as long and fuel smell can permeate the rubber over time. Should I use the teflon tubing? Can I run it the length of the car and be ok? Any thoughts or experience on this subject? Thanks, Shawn |
Jody |
I agree with Jody I would try to run as much hard line as you can, If you are having a hard time in bends you can run hard line inside the rocker area and then use a union on each end to continue. :thumbsup:
Any braided line will be fine front to back.
I have 2 fuel systems on my car, both have returns. My nitrous kit has it's own fuel system. I used the aeroquip -8an socketless hose and fittings. It's 1/2 the price of braided line. Look into that stuff. |
| All times are GMT -7. The time now is 03:28 AM. |
