Complete drive-train for sell!
1 Attachment(s)
Complete drive train for sell! Everything from all of the assesories to the drive line, even the custom crossmemeber for the 6spd trans. EEEVVVERRRRYYTTHHIINNGG!!! Going to be doing a full LS-1 and auto trans conversion to the car. I can send many pictures and even a video. Runs on pump gas and stays cool!
Parts list: 454 ci big block. Stroked to a 496ci. Stock 454 heads with 2.19/1.88 stainless steel valves Victor JR. intake with a Mighty Demon 850 carb. MSD 6AL box, Pro Billet distributor, Blaster 2 coil Hooker Competition ceramic coated headers Moroso 7qt oil pan ATI super damper Hays SFI flywheel SCAT 4340 steel crank (balanced) Eagle 4340 H beam rods (balanced Speed Pro 11:1 pistons (balanced) w/chrome moly rings, with the large cc heads the final ratio is 10.5:1 Comp Cams 6.19, 6.19 lift hydraulic roller cam Comp Cams hydraulic roller lifters Comp Cams Pro Magnum rocker arms 1.7 ratio Comp Cams Stud Girdles Comp Cams titanium retainers Comp Cams dual coil valve springs Pete Jackson gear drive Hays competition pressure plate and clutch disc GM performance parts serpentine belt kit GM performance parts aluminum valve covers K&N extreme air filter kit Holly fuel pump All ARP fasteners T-56 6 speed manual transmission D&D 6 speed adapter kit hydraulic throwout bearing hydraulic slave cylinder Lakewood steel bellhousing New reverse lock out solenoid Professionally shortened drive line Custom built crossmember Hurst billet plus shifter Price: $9000 Location: Vancouver, WA Cell: 360-600-0109 |
| All times are GMT -7. The time now is 12:17 PM. |
