67 camaro parts, LS1 parts and SBC parts. Most are New!
All items are brand new in the box unless noted
CC- 611-16. 10 degree valves locks CC- 503-16. Teflon valve seals CC- 730-16. Titanium retainers CC- 3136. Double roller timing chain All those parts are brand new, still in the box. I`ll sell them for $175 shipped 67 SS350 Emblem kit from Rick`s....$100 67 SS350 Gas cap from Rick`s....$35 67 SS350 Horn button....$20 67 Auto shifter(PG) with new button and spring.....$185. OD conversion for 67 auto shifter and console indicator plate.....$50. CP-127 67 FLOOR SHIFTER FLEXI-ROD ACTUATOR....$40. TH350 Stainless steel hard cooler lines....$65 67 Z28 stainless stell fuel pump to carb hard lines....$45 69 camaro stainless steel front disc brake hard lines....$70. 69 camaro stainless braided flex hoses for front discs....$40. 1990 TH700R4 in good condition (used) with truck convertor....$250 67 GM original in excellent shape auto console shift plate....$45. 4) 15x7 GM ralley wheels with 4.5" backspacing fully restored with brand new trim and new 67 center caps and brand new BFG 255/60 and 235/60 tires....$725 (available soon) JE Forged 383, .030 overbore, 6." rod pistons (Brand New)....$200 Eagle SIR I-beam 6" rods (Brand New)....$200 67 camaro repro fuel tank and sender unit....$135 (available soon) Jegs 6 3/4 internally balanced harmonic balancer....$165 Jegs ProStarter...$125. Jegs SFI approved 168T flexplate....$40. Edelbrock 2 piece aluminum timing cover and chrome timing tab with ARP bolts....$65 Melling Z28 oil pump....$20 CC double roller timing chain....$20. Stock LS1 flywheel (used, but good)....$50 shipped 99 Chevy truck 8.625 rearend, with Richmond 3.73 gears, Truetrac posi, complete with brakes, lines and parking brake cables (posi and gears ran 500 miles)....$750 Summit cast 383 crank with fresh 10/10 turn, needs repolishing from sitting around...$75 317 complete truck heads....$250. 99 bare 853 heads (no notch)...$75. 99 truck throttle body....$75. 01 T/A throttle body....$75. LS1 intake....$50. My zip is 38611 and I don`t have paypal at this time. Will accept personal checks, but will hold items for 10 business days or cashiers check/USPS money order and parts will be shipped immediately. |
What shape are the 317's in? How much mileage, Etc.....
Excellent shape. They were pulled from an 05 truck with 5000 miles on the clock. They may already be sold. I`ll keep you posted on them.
| All times are GMT -7. The time now is 07:16 PM. |
