F/S C4 Dana 44 Complete IRS
4 Attachment(s)
1991 Corvette Dana 44 positraction rear, complete assembly from caliper to caliper. The differential has a heavy duty 1350 series yoke with stock 3.42 (so far as I can tell) gears that are in good condition. The calipers have been rebuilt and (I’m told) powder coated black. The aluminum parts are all cleaned and ready to install. This rear includes the following NEW parts which are already installed:
1. Hub/Bearing Assembly X 2 2. Spicer Heavy Duty U-Joints X 4 3. PST Poly Graphite Bushings. 4."new in box" 3.90 Ring and Pinion set with a complete Overhaul kit (bearings, shims, seals) I purchased this rear end to install in my '68 Camaro and have since changed plans. (Darn you Latral Dynamics . . .) I also have a Wayne Due independent rear suspension installation kit that fits 67, 68 and 69 Camaros in a separate post. $2,300 ($2,700 with the Wayne Due kit) plus shipping. (I’d estimate 200 lbs or so before pallet or crate. Best way to ship would be on a pallet which I can provide.) All items are located in Altadena, CA 91001. |
| All times are GMT -7. The time now is 07:53 PM. |
