buttload of hi-perf parts - check it out
:thumbsup: new tube frame sand-rail chassis:
white powdercoated. new brembo front disc brake setup,vw engine cradle,front suspension, new rack and pinion unit, and various other parts included. $1500 ****:thumbsup: polished plenum and runner TPI tuned port injection system, from corvette, for small block chevy. upgraded 24 lb lucas disc injectors and oem fuel rails and regulator included. manifold base painted red. throttle body included with TPS. $500/obo ****brand new moroso plug wires, glasscore 8mm blue, custom-fitted for pontiac v8 with hei style ignition, lifetime warranty from moroso, part#73539, $60 ****one brand new autometer electric, full sweep fuel pressure gauge 0-100 psi has high and low peak memory function with pushbutton control box sportcomp = black face, red needle, silver bezel $199 ****one pair 1969 351 windsor heads, nicely done mild porting, with rocker studs and guideplates, bare castings $200, no shipping! ****pontiac (BOP) short-tail turbo 400, less then 1k miles on pro-built trans and converter, doug miller unit, ati converter, still in car, hits hard and clean, $800 ****brand new MAC hi-flow catalytic h-pipe for 94-95 mustang gt , new in box $349 ****msd 8964 adjustable knock alert system brand new in box $189 ****:) jacobs nitrous mastermind unit, for EEC4 mustangs,progressive notrous control, rev limiter, fuel pressure safety shutoff, shift light, more all in one 1/2 din size unit. $200 ****holley oem reproduction musclecar carb, for hi-po big-block chevy apps, used, off running car, fine shape, list 4346 $300 ****bart 15x7 nascar wheels, black, 1 pair only, 5 on 4-3/4, brand new $110/pair, 2 only ****ford 302 shortblock, used core, assembled, non-roller $150/obo ****hardly-used and in-garage only, custom fit top of the line car cover for 94-98 mustang, gt, cobra, $150 ****Detroit Speed DSE intermittent wiper kit, new in box, for 67 camaro/firebird, part #121001, $275 ****one old-style vericom 0-60 1/4 mile tc computer big old-fashioned looking escort radar detect style case, no bracket, power plug could use a re-solder; it's intermittent if you let the cord flop heavily, no bracket in original box, works fine except as noted above, computes hp, torque, etc, can be mounted on side window for lateral g testing, $89 plus ship ****eibach pro-kit spring set, brand new, part# 3885-140, fits 2000-20005 chevy impala ss and like-bodied cars $219 ****suspension techniques swaybar, #50125, nissan sentra ****unorthodox racing 06054 honda underdrive pulley, new in box ****K&N 57-2507 FIPK kit, new in box ****comp cams/hartman composite valve covers red small ford black small chevy both pairs new in box ****new in box lifters, pre-johnson issues, new old stock: crane:C37-16, C49, 99377-16 hi-intensity (variable duration) comp cams: 941-16, 822-16, 812-16, 834-16 crower: 66000-3 small block chevy ****accel igntion box #49327, for 1996-97 LT1 powered vehicles only, new in box ****MAC underdrive pulley, part#4696, 4.6 mod motor mustangs/t-birds, 2 sets, new in box $89 **MAC underdrive pulley 1990-98 mustang,t-bird, with 3.8 V6 $89 ****2 ford motorsport M1007-D178 cobra wheels, 17x8, new in box demos, genuine Ford $270/pair ****richmond gears, new in box, chevy 8.2 10-bolt, 3.55 ratio $229 ****precision gears, new in box, 4.56 ratio, dana 44. have install kit for same also. ****precision gears, new in box, gm 10 bolt 8.5 corporate, 3.08 ratio ****;) from 1981 trans am: both front spindles, complete with all braking parts, including not even broken in EBC greenstuff pads, and new russell stainless steel DOT legal flex lines, installed same time as the ebc's. calipers were installed several years ago, but have same mileage as above - car was in storage. these are the larger big-car calipers as used on full sized gm cars. assembles as pulled from car via unbolting balljoints and tie rods. spindles unboogered and straight/true. can ship in ultra sturdy boxes as provided by baer with the new stuff. best offer, will ship. $250/obo ****also new set rear pads for a ws6 disk brake car, 20 bucks plus ship, unused but i lost the box and have brand new ones just in with the new fronts. ****1981 TRANS AM oem slap-shifter, cable, related bits, knob, button, etc - still in car, best offer ****oem 81 TA front seats; vinyl and lower foams shot; mechanicals/frames/sliders all very good; both sides, best offer ****2 1977-UP SHAKER SCOOPS ****:hail: 1 set really nice tan sport seats, just like summit/jegs, synthetic leather (nice, actually) new in boxes, $359 FOR THE PAIR! ****one only black synth leather driver side Monaco seat, like recaro, very very nice, unused but has been installed, with sliders, no shipping,$545 new, sell for $259 ****barely used, very low miles, pro-5.0 shifter for gm t5 camaro and firebird. no handle, just the shifter. perfect condition, perfect working order $159 shipped ****new in box grant carbon fiber steering wheel trim ring for 93-97 camaro ****1 flowmaster catback exhaust system part # 17224 for gm trucks 1996 - 1999 Chevrolet / GMC 2500/3500 Truck Siverado/Sierra 3/4 Ton & 1 Ton 5.7L HD & 7.4L 2 & 4 Wheel Drive Extended Cab / Long Bed CrewCab Dually - 155" & 168" WB 3.00" Outlet 50 Series Big Block MufflerHUGE VARIETY American Thunder Single pipe out the Side exit (SOS) new in box $249 oem 2nd gen trans am front swaybar, 1-1/4" diameter, used, undamaged, best offer ****camaro/bird second gen 1.25" front swaybar with Eenergy poly hardware, best offer, no shipping ****for sale, brand new in the box: one aftermarket replacement S10/S15 first gen (1982-93) tailgate. not gennie GM; got from a bodyshop friend. $100 ****used gmc syclone steering wheel, complete with horn button, leather kinda rough but not torn. $75 ****new grizzly bed mount double-tube rollbar. 2 boxes, main and supplementary. yee-haw! fits 1st gen S10 trucks $199, black, new in boxes. ****brand new chromed replacement 1 piece grill/headlight surround for 1st gen s10 vehicles - blazer, etc. stock replacement type for 1992 upmarket trucks. $99 ****used parts: oem syclone front swaybar, with energy greasable graphite bushings. will fit all 1st gen 4x4 S10 based vehicles - blazer, bravada, typhoon, etc. $75 ****2 rear, 16x8, mesh style pontiac trans-am GTA wheels, gold mesh, very good condition, lighter of the 2 variations, have caps $150/pair, with caps plus 2 spare caps included. ****1981 trans am blue 3-spoke steering wheel with horn button and bird logo. needs recovering, paint chipped on spokes, small chip in hub. $50/obo ****81 trans am factory front seats. upholstery and foams shot, mechanicals good , includes tracks/sliders in good working order $100/pair ****1 pair stock first-gen s10 side view mirrors, good shape, not cracked, $25/pair also for sale, many speed parts, heavily modified gmc syclone, more. |
also this:
:willy: analog holley 900cfm 4V fuel injection setup. bolt right on in place of a carb; lower installed height then a carb for increased hood clearance, extremely!!! low miles, absolutely perfect working and physical condition. comes with optional closed loop kit with heated o2 sensor (sensor in excellent condition) knob style ecm, no laptop needed. all manuals and other aftermarket literature included. fuel pump included, harness, etc. coolant temp sensor included. this is an alpha-n system; appropriate for large-cammed engines and/or single plane intakes; vacuum signal doesn't matter. system requires running a return line; i used the oem return line with no problem whatsoever. TB has built-in (adjustable) fuel psi regulator. |
My God I hope you type faster than me!! Good luck with the sales!! ;)
PM send on DSE wiper
Jason |
i type at the speed of Warp Hunt and Peck, sadly for me.
i keep a working copy of the list and change update it as stuff gets sold/added in a text file, or i'd kill myself! |
to the top:D
Chev or GMC grill? and can you shoot me a pic... would be very interested.. thanks |
sorry, the grill's still factory bagged and wrapped in foam, but will take a photo still if you like as it's packaged.
but i tore a bit of foam off and looked: it's chrome, GMC not chevy, the actual grill portion with the horizontal ribs is black. for reference since i own one, it's exactly the same as a syclone/typhoon grill but the outer surround is chrome. and it's aftermarket, not gm. thanks mike |
bronco is sold.
and, bump. |
bunch of this stuff and lots more still available; post or pm with any needs or questions please!
-mike |
| All times are GMT -7. The time now is 08:23 AM. |
