6.0L LSx Cam. Piston/ Valve Clearance?
Has anyone got an idea about the max lift i can squeeze before needing to notch the pistons? I read many posts here and there on different combos and Man! These engines seem to be able to take over .600 without anyone mentionning notching from what i read!!!
I'm interested in about .630 and [email protected] for my application and am looking for information/ confirmation. Thanks, Lead. |
Come on guy's!
31 clicks and no one has an idea???? Nobody runs an LSx here! :lol: 'Guess i'll have to jump over to LS1tech.... Lead. |
What heads are you planning on running? I would say you are gonna be close on PTV(assuming stock 6.0 heads) with that cam you could go something more like a Comp 232/236 LSK lobe which should put in the lift range you want and make some killer power.
Hey thanks Pete,
Yeah, at the moment i'm shooting for the stock heads. I just ordered the intake (Vic Jr) headers (Hooker s-comp) oil pan and p-up (Moroso) + the mounts. Next up are the w/pump, cam and some Nasty prformance Valve covers! I'm also waiting on the T-56 to show up on tuesday. Did you see the cam you reffered in a particular application, dyno or something? I have seen a few interesting combos's... Just hard to know if the printing was legitimate...The errors that happen in some magazines are to be taken into consideration so i have my brakes on towards those things a little. Lead. |
It may fit, it depends on the valve events, and the heads used. I would check for your self the pistons may need to be flycut.
I've got a crane 228/232 .600/.600 in my LQ4 6.0. I have the 317 aluminum heads which were milled .020 and no problems to report yet. She runs good.
I wouldn't go anything over a .600 lift on an LSX based engine without flycutting the pistons. The cam in my 408 is a 244/248 duration.612/.615 lift, my heads were milled .030 and we had to go with the relief cuts.
| All times are GMT -7. The time now is 08:07 AM. |
