67-69 firebird camaro rear disc brakes & brackets
I have a used rear disc brake kit and brackets. This is everything you will need to mount the brakes to your 12 bolt or 10 bolt and use your emergency brake. The brakes are off of an ls1 4th gen camaro and includes the emergency cables, rotors, calipers, etc. Comes with a new, unused mounting bracket from BRP for use with your rear end. $300 or best offer. Brakes located in Chicago, IL.
| All times are GMT -7. The time now is 08:53 PM. |
