Go Back   Lateral-g Forums > Technical Discussions > Brakes
Old 11-26-2010, 08:31 AM
69VanNuys's Avatar
69VanNuys 69VanNuys is offline
Default Use? Hydratech & Heidt's Power Steering Valve
I am considering the installation of the Heidt's Power Steering Value (PS-101) with the Hydratech braking system. I understand it will allow adjustment of the brake and power steering feel. Anyone have one installed or work on one?
'69 Camaro RS/SS 505 BBC Convertible
Old 11-29-2010, 05:06 PM
XcYZ's Avatar
XcYZ XcYZ is offline
I'm using the Heidt's adjustable bypass on my Hydratech system. Here's my thoughts on it:
First off, there's no PS noise. I was wondering about that, but it's a non-issue.
The pedal has less initial bite.
The steering is noticeably firmer when I'm parked/not moving. It's slightly firmer at cruise speeds.
The biggest plus that I've experienced is there's less initial 'bite' or 'hit' of the hydraulic assist unit. The steering was only marginally affected. I've gone from one extreme to the other with the bypass and that seems to have been the biggest change.
Hope this helps.
My LS7 69 Camaro
Old 11-30-2010, 02:35 AM
rwhite692's Avatar
rwhite692 rwhite692 is offline
That is good to know, Scott. When I had my original setup on my car (C5 front brakes w/Hydroboost) the intial bite when getting on the brakes was something I never did get used to.
______________________________________________
1969 Camaro/ Tom Nelson TT 434 / Wayne Due C5 / DSE QLink / and a bunch of other stuff...
Project update thread here:
https://lateral-g.net/forums/showthread.php4?t=12743
My Lateral-G Page
My Shop Build:
http://www.garagejournal.com/forum/s...ad.php?t=16310
Old 12-14-2010, 10:25 AM
PhillipM PhillipM is offline
Hope this helps.
Is it possible to install the bypass only on the brake side or if you put it in anywhere, it affects the entire system? Just wondering. We have the same problem with our hydra unit. WAY too much pressure to the front pads. Were talking 1400psi under hard braking.
Old 12-15-2010, 09:31 AM
Hydratech®'s Avatar
Hydratech® Hydratech® is offline
Supporting Manufacturer
HydratechBraking.com
First, a well functioning vacuum booster can generate up to 1200+PSI~, so we're not all to far past that point. The power source for the hydraulic brake assist system is the PS pump, so detuning the PS pump for gallon per minute flow rate (GPM) is what the Heidt's valve does. This is a step in the right direction when it is felt that a hydraulic brake assist unit is providing too much response, though the max pressure relief setting in the PS pump is also a factor (and is separate from GPM). If your PS pump is for instance pumping out 3.5 GPM and backing that up with 1500 PSI max pressure relief, this will provide the brake assist unit with a VERY STRONG power source. Hitting a vacuum booster with a constant source of 26" of vacuum is a comparable scenario. Conventional wisdoms accept that a vacuum booster will not provide much assist when a big cam has been installed, providing 10-13" of vacuum resulting in hard pedal, and that is when the vacuum reserve tanks and pumps are applied to artificially supply a higher power level to the vacuum booster. Spoken the other way around, if you have a stock late 60's / early 70's Saginaw PS pump on say your Chevelle, you are looking at typically 2.2 GPM and 1100 PSI max pressure relief. Under this circumstance with this stock pump, the hydraulic brake assist unit will not have as much amplification as compared to 3.5 GPM and 1500 PSI max pressure relief. These systems will actually run down as low as 850-900 PSI max pressure relief, though I feel they then become somewhat underpowered and can impact steering operations in tight parking lot maneuvers if you have to brake and steer hard into a parking spot (as now we are on the flip side of the discussion in not having enough power from the PS pump).
The installation of the Heidt's PS valve between the PS pump output and the brake assist unit will allow for detuning the actions of the hydraulic brake assist unit. With the steering gear downstream of the brake unit, and the PS flow control valve being installed right after the PS pump / before the brake assist unit, this will also impact the steering (as the steering gear will also see reduced pressures / volumes). If you are for instance pleased with the brake assist, BUT want to knock the assist down in the steering, you would then alternately install the Heidt's PS valve in the second high pressure line that comes out of the brake unit that feeds the steering gear. This way the brake unit operations will be unaffected, though you can now blow off the pressures / volumes available to the steering gear. Note that even though the Heidt's valve is capable of bleeding off fluid back to the PS pump, it still doesn't provide a linear control of the PS pump max pressure relief.
The other aspects of this type of discussion is to look at all of the other variables. What type of vehicle? (which will determine the brake pedal mechanical ratio) What type / bore size of master cylinder is being run? The larger the MC bore size, the firmer the pedal and less line pressure and vice versa. The type of brakes at the wheels is also a variable, as some types (like the C4 Vette based designs) require high line pressures to really function well, while others do not. I would also like to point out that certain master cylinders go into more than just MC bore size discussion, as some are also biased differently. The new design Wilwood 260-8556P for instance is listed as providing a 75 front / 25 rear brake general hydraulic bias. The classic stock C3 Vette MC is closer to a 65 / 35 general bias. This being stated, the Wilwood MC could generate much larger pressures to the front brakes as compared to the rear brakes in a side by side comparison to the C3 Vette MC in certain scenarios. Do note that there are large variables in the brakes at the wheels that can really change these calculations around - caliper piston bore sizes, caliper piston travel required to acheive clamping force (which eats up volume and affects pressure), brake line flex hose expansion, even wheel bearings and axle shaft deflection all comes into play. If you are getting high pressure readings to the front brakes, you should see what is happening at the rear as it may actually be too low. In this scenario, locking up front brakes well before the rears are fully in the game can occur. This is usually brought about due to mismatched brake combinations front / rear with differing pressure and volume requirements. If your front pressure is way high, yet your rear pressures are way low, you may feel that the hydraulic brake assist unit is too powerful by resulting in premature front wheel lockup during hard braking (as the rears aren't coming in strongly enough).
With all of the possible variables in modified vehicles, there is always much more too it than meets the eye at first glance. Phillip , if you would like to discuss your scenario further here, please provide as much information as possible:
* Vehicle Year / Make / Model
* MC bore size / type
* Our model # of brake assist unit
* The exact specs of your brakes at the wheels (type, size, pad compound)
* What type of proportioning valve
* What type of PS pump (specs if possible)
* What type of steering gear
* Tire sizes / compound front and rear
* Suspension mods (spring rates and shock valving also come into play)
There IS a difference - Thank you for choosing Hydratech!
Paul M. Clark <-- the Ukrainian - Slava Ukraini !
Founder / Master Engineer
Hydratech Braking Systems ®
www.hydratechbraking.com
Old 12-24-2010, 09:24 AM
protour73 protour73 is offline
Hope this helps.
I love the idea of softening that initial "bite" of the boost unit.....AND a good byproduct of that softening of the brake unit will be a stiffening of the steering, which for my taste is just slightly touchy for me.
Scott, do you have any good pics of the plumbing of the Heidt's Adjustable Power Steering Valve (part# PS-101) <--- same one right?
thanks....
Old 01-01-2011, 12:32 PM
Hydratech®'s Avatar
Here are a few shots Scott passed along when he was first setting up the Heidt's PS101 valve in early '09 - his engine compartment has come a long way since!
This was an initial installation that he has since reworked for better overall layout and appearance.
Old 01-01-2011, 08:48 PM
WOW, thanks Paul, that's perfect!!! ..... and thanks Scott!!
