Old 12-09-2012, 12:55 AM
RECOVERY ROOM's Avatar
Supporting Vendor
RecoveryRoomInteriors.com
Default CNC machine foam suppliers
Im looking for a foam that we used once and was told it was called Machine foam, Machine shops use it for prototyping parts. It can sanded and fiberglassed over. I know about RC airplane foam, I need at least a 10lb density. Any suggestions or links to start my search would be welcomed
TRACY WEAVER
www.recoveryroominteriors.com
Old 12-09-2012, 01:04 AM
badmatt's Avatar
badmatt badmatt is offline
http://www.precisionboard.com/produc...urethane-pblt/
Basically called polyurethane foam. You can buy it in a 2 part mix that expands too.
Ive used blue insulation foam board glued together.
97 Sonoma "NERA": Pile O Sh*t. Literally.
Old 12-09-2012, 10:19 AM
Depending on where or how you need the surface - you can use pvc foams that you can get at lowes, menards, home depo, etc. If you're doing flat or low contour surfaces or have a need to directly machine in a groove or some other tooled surface, pvc requires less finishing steps since its a solid material. You can also do minor heat forming/bending with pvc and it will hold it's shape once cooled.
Sounds like for interior work you'd most likely use polyurethane foam like Matt suggested.
Jim
My Project: 65 Porsche 356G
https://lateral-g.net/forums/showthread.php4?t=5109
Old 12-09-2012, 01:26 PM
tazzz2_ca's Avatar
tazzz2_ca tazzz2_ca is offline
Like to be a Bar Fly on what project has you thinking about this stuff,,,, I'll bet it'll be a real show stopper....
-73TA WarPath (Summer 2016)
-72RS Il Vagabondo
-70 Blue Formula "Project Cochise"
-70 Z shell
-70 Formula shell
-70 Formula roller
-68 Eldorado
-67 Coupe De Ville convertible
Old 12-09-2012, 07:13 PM
Supporting Vendor
Looks like what I want, Thank you. Ill be calling them Monday.
TRACY WEAVER
Supporting Vendor
TRACY WEAVER
Old 12-09-2012, 08:30 PM
70 chevelle 70 chevelle is offline
http://www.avtcomposites.com/cgi-bin...&category=1230
Can't wait to see what your working on.
Tony L
You can't fix stupid!
