Item Location (City/State): Scottsdale AZ
Price:$15,500
Description:1977 Chevrolet Nova "White Lightning" Pro-touring, Autocross, Drag Ready
Professionally built and executed with all the best parts, this car can do it all and do it in comfort.
Solid rust free Arizona car with all original sheetmetal and a U.S. Body bolt on fiberglass cowl hood.
Side moldings were removed and all trim was blacked out. Perfect grille and bumpers. LED taillights and blue halo
LED headlamps. All glass is dark tinted
Interior is all new maroon cloth with 4th gen Firebird seats (driver's power), console with gauges,power windows, power door locks with custom door panels without lock button and remote entry, tilt and telescopic column with Grant wheel,
custom dash with Autometer gauges,remote trunk release, Retrosound 4 speaker stereo MP3 player, LED lighting, cruise control, map lights in mirror, factory air conditioning with GMPP serpentine accessory belt system and full courtesy lighting.
Motor is a balanced 1972 406 cu.in. small block with AFR aluminum heads putting out a true dyno tested 370 h.p. and 475 ft. lbs. at the rear wheels. All the best internal parts were used with no expense spared. Too much to list but I have all the specs. available. Pump friendly 10.5:1 compression ratio. Trans is a Tremec TKO 600 5 spd. with Hurst handle shifter a McLeod clutch and scattershield and line loc. Custom made 3" driveshaft with 1350 U-joints. Rear end is an 8.5" with welded tubes. Eaton 3:73 posi unit, Timken bearings and 30 spline Yukon axles. Totally bullet-proof.
Suspension is all new BMR pieces including lowering springs, 1 1/4" sway bar,tubular upper and lower control arms and subframe connectors. Polygraphite busings both suspension and body. Steering is all MOOG components with an AGR 12.7:1 quick ratio power box. Brakes are 12" SSBC disc all 4 corners with Willwood calipers front GM aluminum rear. Lines are all braided stainless steel. Corvette master and prop valve. 17x7 and 17x8 Show Wheels Streeters with BFG G-Force rubber.
As you can see, all systems on this car have been upgraded. It's tight as a drum and performs just as well. For sale for a fraction of what it would cost to build it yourself. Buy it and start having fun immediately. It needs nothing but a new driver. Only $15,500
