Old 09-22-2008, 09:38 AM
sacarguy sacarguy is offline
Default update on my 66 pro touring mustang, project wild horse.
So far the things I have done.
full frame made out of 2x3 steel
replace floor pans that needed it
replace lower rear quarter and inner panels
seam seal entire under side of car
fabricated firewall and trans tunell.
paint whole underside of car with 3m body sholtz
tub car and install martz four bar rear suspension
install heidts mustang 2 ifs and fabricate inner fenders and upper fender mount rails.
I will be mounting the suspension back on the car and hanging fenders and starting body work now setting all the gaps etc, shaving the drip rails and smoothing the roof
Fabricate the dash mods and center console
fabricate the mounts under the dash for the ac system
fabricate the mounts for the 07 gt-500 motor and 5 speec tk0-600 transmission.
trans tunel already coated
wheel tubs
through floor new fram rails
Old 09-22-2008, 09:41 AM
Default pics
rear suspension
new firewall
front floor pan and trans tunel tacked in
drivers floor pan and new through floor full frame.
Old 09-22-2008, 09:45 AM
Default pics
rear trunkl tubs seam sealed
sealer you see inside fender is there to protect inside of the quarter panel weld I will be body shultzing the whole trunk and inner quarters as well then painting it with splater paint for a strong durable atractive trunk finish.
new lower quarter panels installed
just a pic of the car with the fenders hung and suspension on it.
Old 09-22-2008, 09:53 AM
Tom.A's Avatar
Tom.A Tom.A is offline
Looks great. Keep us posted
Tom
Old 09-23-2008, 11:09 AM
Got the whole car into three coats of green self etching primer
Then painted the whole out side of the car in black epoxy, so now no worries about rust while I seam seal the inside.
Then I will put the lizzard skin down then start on all the custom dash work and the actual body work.
Default k
more
Old 09-23-2008, 02:19 PM
GHOSTDANCER GHOSTDANCER is offline
Good looking project
Old 09-24-2008, 05:59 AM
dmc69's Avatar
dmc69 dmc69 is offline
lookin good!
DMC69- 69 SS350-LS3/6speed
Old 09-24-2008, 06:57 AM
steemin's Avatar
steemin steemin is offline
Very nice.
What size tire will you be using in the rear?
Will the car have a back seat?
"Quicksilver"
G Force Design Concepts #004
Pro Touring 1965 Ford Mustang Fastback
FRPP 347c.i./450hp
SSBC 4WDB,Budnik M5's
G Force T5 etc..
FOR SALE
Old 09-24-2008, 10:45 AM
Default tires
rear will be 335 or 345 front a 265 or 275
