Old 11-24-2010, 12:28 PM
Default Awesome New Pre Wired Fused Multi Relay Panels
Need relays for:
Fuel pump?
Electric Fan (s)
Headlight motors?
Nitrous?
Amplifiers?
Anything with a heavy draw, more then 10 amps should be run on a relay. Many components have a low continuous draw but the start up hit is a very high amperage like electric fans for example.Multiple relays can get pretty messy, hard to attach and hard to trouble shoot.
I am so excited I found a way to clean up PIA relays and fuses. On the left side of the first pic is what I had in my Street Racer, on the right is our new Pre Wired Relay Panel. These things are so cool. One power wire and one ground wire powers all the relays, each is fused, hook up the signal wire and output wire and it is all done. No making a panel, looping power and ground wires. As close to plug and go.
My Street Racer has Dual 16" fans (28 amps hit each, 12 amps each continuous), Electric water pump (16 amps continuous), and 2 stages of NOS (33 amps per stage). These Relay Panels house (5) 40 amp relays all in a compact 8"L X 3"W X 2"T package
We have these in stock in 3, 4 and 5 relay versions and will customize label the Relay functions on the relay panel and send custom instructions for your specific application like the ones you see in the pictures.
The Prices are as follows
3 Relay Fused Panel $249
4 Relay Fused Panel $269
5 Relay Fused Panel $289
On the left shows the way we did it back in the old days, now we have a MUCH cleaner package.
Panels will come, at no additional cost, custom labeled for your specific needs, or blank if you choose
We will also provide, at no additional cost, detailed instructions for your specific needs.
Frank Serafine
