Old 09-29-2009, 09:43 PM
Steve1968LS2's Avatar
Would you like me to move this one too Cris?
Old 09-29-2009, 09:46 PM
Cris@JCG's Avatar
Cris@JCG Cris@JCG is offline
Yes! Thank you Steve
Old 10-01-2009, 07:14 AM
syborg tt's Avatar
Originally Posted by Gonzo View Post
Here are some pics on the suspension on this build & finally got it off the jig & rolling on wheels!!
I like the wheel tool, I have the one made by Wheel Tech and it looks like you made your own ???
marty-mj
Old 10-01-2009, 09:18 AM
OneCamaro OneCamaro is offline
Default Back spacing (front)
315 40 19 tires with 19x12 in the rear.. 255 40 18 tires with 18x9 in the front
What back spacing did you do with this wheel and tire combo? I have the same sub frame and engine combo. Did you try a 275?
Did you use the factory A/C bracket? And are you using vintage air?
How far back did you have to cut the shifter hole from the original location?
Thanks in Advance, nice to see your build. Great Job.
P.S. Great machine work and I love what you did with the sub frame connectors.
Old 10-01-2009, 07:54 PM
Cris@JCG's Avatar
Yes we made our own to wheel simulator.. Used on other builds to order wheels & has worked out as a great tool!!!
Old 10-01-2009, 08:24 PM
Cris@JCG's Avatar
The front offset is 18x2.5 outer & 18x6.5 inner as I gave it to Forgeline.. I don't have it it on paper for the rear but will get it for you when I have the wheels off the next time..
Did you try a 275? No.. But I am sure it will work will max offset..
Did you use the factory A/C bracket? My machine shop made the brackets to mount the A/C compressor that was given to us by Vintage Air @ the time.. Now the have a smaller A/c compressor
I wanna say about 2 inches..
Thanks in Advance, nice to see your build. Great Job. Thank you!! We try to come up with new cool things!
Old 10-02-2009, 10:25 AM
syborg tt's Avatar
Nice work. I have the one from wheel tech but i like the 3 mountnig positions better. Ron ( WMC Design ) & I have been playing with making a new version for years and I really like how beefy your is.
marty-mj
Old 10-05-2009, 07:52 PM
Cris@JCG's Avatar
Default Custom Pedals
Here are some custom pedals that were made to fit the Wilwood base!! They have adjustable pads & have the throttle pad in design!
Old 10-05-2009, 08:48 PM
Your custom billet stuff is just sick....
Old 10-05-2009, 08:53 PM
Cris@JCG's Avatar
Thank you!! Got some pcs we made for you @ the shop!!
