Old 01-11-2010, 09:33 PM
Default HELP ID'ing HOSE CLAMP!!! (not gates power grip)
Ok.... so take a look at Mark's Jackass intake tube ( 4 inch diameter I believe) and help me find out what kind of clamps he used?!?!?! They are super clean black clamps, and unless the joint/bolt etc is hidden underneath, they look completely smooth......
the gates clamps are wider and dont go that big... soI have no clue. BDL inustries has a nice clamp but they have visible fasteners and hinge points...
any thoughts?
Tyler
HPI Customs
Manitoba, Canada
www.hpicustoms.com
Old 01-11-2010, 09:53 PM
Old 01-11-2010, 10:34 PM
It's a lot easier just to ask him yourself... I'm sure he'd know what they are.
You can PM people... do you know how this is done?
Old 01-11-2010, 11:35 PM
deuce_454's Avatar
are you talking about "Gates PowerGrip®" Hose Clamps ?
from 1/2 to 3-5/8 diameters... (no 4 inch though)
http://www.jegs.com/p/Gates/Gates-Po...43359/10002/-1
Jake: Hit it.
Old 01-12-2010, 06:53 AM
Bow Tie 67's Avatar
Bow Tie 67 Bow Tie 67 is offline
He used hose clamps with black heat shrink.
Matt
Project: " Chain Reaction "
A.K.A. " BIG " by wife, biatch in garage.
1969 RS Camaro, L92 T56, Chassisworks sub, Quadra-Link, Bear, Ford 9".
Old 01-12-2010, 11:10 AM
Northeast Rod Run's Avatar
Northeast Rod Run Northeast Rod Run is offline
I use heat shrink on some things. it's super cheap (but doesn't look it) and it cleans up things a little bit. an ISCA judge told me about that trick before
Old 01-12-2010, 09:31 PM
I havesent Mark some PMs, but i know he's busy and didn't want to bug him.... I can post a pic from his threads, I just figured someone might know the car....
I specifically said I didnt think they were the gates ones, as gates only lists up to 3 1/4 inch and the throttle body on the LS9 is 4 inches diameter.
Hence the fact I thought they were not Gates shrink clamps..... I have a 4 inch throttle body too..so I wanted to find out!
Tyler
HPI Customs
Manitoba, Canada
www.hpicustoms.com
Old 01-12-2010, 09:32 PM
10-4 on the hose clamps with black heat shrink..... thanks
Tyler
HPI Customs
Manitoba, Canada
www.hpicustoms.com
Old 01-14-2010, 07:56 AM
alright so I took a look and couldn't find a picture that shows the area well enough. Anyone care to help me out and link or post it? This sounds like a neat trick.
