Closed Thread
Old 01-29-2010, 09:30 AM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Originally Posted by skatinjay27 View Post
hell Im even more scared to go for a ride!!!
AJ, is this because of Todd's driving or his new "monster" engine?!?! lollll..
Just kidding Todd. I'm anxious to see and hear this bad boy!!
  #1142
Old 02-04-2010, 04:29 PM
g356gear's Avatar
g356gear g356gear is offline
Hey Todd,
Where did you find those plug wire insulators?
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
  #1143
Old 02-04-2010, 05:44 PM
You can find them here in colors ---
http://cableorganizer.com/insultherm-spark/
But I'd check Summit Racing...
  #1144
Old 02-04-2010, 07:00 PM
Here ya go -- I'm doing Todd's secretarial work now...
These are available from Summit Racing... $16. I post the black versions but they also have colors.
http://www.summitracing.com/parts/DEI-010511/
  #1145
Old 02-04-2010, 09:09 PM
Thank you Greg for your considerable skills. I wouldn't run wires under the header again. The photo is a header setup for a stock subframe, my new headers are tighter. I have my engine torn down and after inspecting all the wires and boots it was a matter of time before I had a misfire. Mine will be along the valve cover rail. Function then form for me.
  #1146
Old 02-05-2010, 08:06 AM
chr2002ca's Avatar
chr2002ca chr2002ca is offline
...I wouldn't run wires under the header again...
Agreed. I spent countless hours trying to get my wires running under the headers and still went through 2 sets before giving up and running them along the valve covers also.
I hope your new engine is coming along nicely Todd!
Chris Robinson
1969 Camaro SS/RS, 489 ZL-1 MPFI, T-56 Mag
  #1147
Old 02-05-2010, 08:33 AM
redfire69's Avatar
Awesome engine Todd. What BBC headers do you guys recommend w stock SF and a steering box? Do they all have to be "clearanced"?
Ron
69 Camaro Redfire
  #1148
Old 02-05-2010, 08:42 AM
Aschle's Avatar
Aschle Aschle is offline
Granted, I have a small block, but in my 91' Camaro I have my wires run underneathe the headers and they are doing great. I routed them that way back in 99'
Jason
Jason Aschle
________________
1969 Camaro
1957 Chevy 150 Utility sedan, semi-pro touring
2016 MB s-AMG E63
  #1149
Old 02-05-2010, 09:33 AM
You can't beat a set of Lemons. Mine fit perfect.
Jason, I'm running 2 1/8 primaries(Bigger than most cars exhaust) and the headers must hug the block tight for the steering shaft. The factory ran them under in many of the late model small block applications. Two different ball games. The last thing I want is to develop a misfire in the middle of a race or cruise. I always carried an extra plug and wire just because I knew it was a compromise for cleanliness.
  #1150
Old 02-05-2010, 10:17 AM
chr2002ca's Avatar
Same deal with me. Big block with 2" primaries and they hug the block close due to my steering box(and I would not recommend Hedman headers). Passenger side was easy on the wires. Driver's side was a nightmare, no matter how strategic I was or how much heat shielding I used. It just wasn't meant to be.
Chris Robinson
Closed Thread
