Old 03-09-2010, 12:43 PM
Sti_Guy's Avatar
Sti_Guy Sti_Guy is offline
Default Light 12v Optima?
OK so what im looking for is a light weight optima battery. I want the quality of the optima battery but in a smaller package. Maybe one that is half the size/weight of the current unit i have. Or has this just been something others have brought up and just never goes past that point?
Old 03-11-2010, 01:15 AM
SLO_Z28 SLO_Z28 is offline
The yellow top group 51 is strong enough to crank over most applications. Id look into that.
Old 03-11-2010, 07:07 AM
tukes23's Avatar
tukes23 tukes23 is offline
Default Oddessey
All of the optimas are pretty much the same size and weight. If you're looking for something lighter and small but still with the same quality, I would look into Oddessey batteries. They seem to be a bit more expensive than Optimas but the quality is better and you paying to lose quite a bit of size and weight.
Old 03-11-2010, 09:26 AM
Might try 2 six volt Optima batteries. Not sure if there is a weight difference - might actually weigh a bit more. We used 2 in series in a 33 hot rod. Mounted them in the left side panel of the trunk. LS7 engine - No problems cranking it over at any time.
Jim
My Project: 65 Porsche 356G
https://lateral-g.net/forums/showthread.php4?t=5109
Old 03-11-2010, 05:10 PM
nvr2fst nvr2fst is offline
If its in the budget
Braile
Old 03-11-2010, 07:56 PM
David Pozzi's Avatar
Optima 8071-167 is a group 57 T2 yellow top, it's 450cca 27.2 lbs, and I was told it is used in race cars for lighter weight. There might be a red top version with more CCA's.
Any AGM battery is already lighter than a flooded type battery.
http://www.PozziRacing.com
Old 03-12-2010, 06:12 PM
If you want light weight -- these are even made in carbon fiber!
http://www.braillebattery.com/index....tteries/b3121/
Old 03-12-2010, 08:37 PM
Sti_Guy's Avatar
I've done some research on all the other brands out there, but I really have my reasons for wanting to stay with an Optima. The market could use another contender. Ill just stick with what i have the battery hold down is already welded in the car anyways.
