Old 07-11-2014, 12:43 PM
MCB Matt's Avatar
MCB Matt MCB Matt is offline
Default Push Button Start with RFID key (keep the key in your pocket!) Under $499!!
Hey guys, we are now Carrying Keyless entry/push button start systems. Just walk up to your car, it unlocks and you can jump in and hit the start button! They are a very high quality kit, worth of being installed in basic to super High end builds! These kits are under $499.... That is a VERY good price for all you get in this kit!
Please PM, email or call for details, there are several options available:
Below is a quick list of some of the features and options...
Start Button with LED Status Indicator
All 2GO Keyless™ come standard with our "T1 style" stainless steel LED Illuminated Start Switch. This is a top quality / heavy duty cycle switch with an attractive "soft brushed" finish. An Illuminated LED ring indicates system status. Switches are pre-wired to a 36" plug in harness. Available in 3 LED colors; RED, BLUE or GREEN.
Five Independent Feature Control Channels
Four channels are user programmable (either Latched or Pulse) can be used for virtually any option such as Remote Keyless Entry, Shaved Door “Pop” (single/dual), Remote Trunk release, Automatic Window Roll up, Lighting or Video activation, and a 5th "Proximity Channel" that activates automatically when you approach your vehicle, provides endless versatility to create customize operation of whatever you can dream up.
Advanced System Control Module
The system control module has 60A high current relays which are right on board, eliminating all unsightly and failure prone external relay wiring. Individually controlled circuits for Starter, Ignition and two separate Accessory circuits allows the system to install into any vehicle. One ACC circuit switches OFF during starter crank (to minimize current draw from components like A/C) and another that stays ON (for components such as computers.
Programmable Starter Delay
For vehicles requiring time for fuel to pressurize on other systems to warm up before the engine cranks. The PBS II provides a programmable Start Delay circuit. It allows you to select a delay from the time you press the start button until your starter cranks of up to 7 Seconds.
Built in MSD Filtering system
Advanced filtering circuitry removes noise and electronic spikes associated with many high performance ignitions, saving money an time by eliminating the need to buy separate ignition filters.
Full Ignition Switch Functionality
Using brake pedal controlled switching the system fully emulates the functions of a traditional key switch.
Want to operate accessories without starting your engine?
Just use the Brake to select between different Ignition modes:
"Accessory Only Mode" ( Radio )
"Accessory + Ignition Mode" ( Heating / Fans / Radio )
*** At any time you can go directly to "Start Mode"
Choice of Start Buttons
Customize your Ultimate Keyless installation even more with one of our optional Start Buttons choices. We start with of the most beautiful OEM buttons available and individually modify them to work with 2GOKeyless™. It's the perfect finishing touch!
Emergency Bypass
Should you ever lose or damaged your iTag™ the system includes a Emergency Backup PIN# Card that will allow you to start your vehicle in a emergency.
A 2GO KEYLESS™ exclusive feature!
2GO-PBS-II RFID Push Button Start / Keyless Ignition with 5 output channels.
The iTag™
TX2-PBSII-Expands your possibilities even further, with the ability to remotely control power locks, shaved doors, power windows and trunk all from one iTag™ transponder!
Are you building something special and needing one unit that can do it all? Then the 2GO-PBS-II is just what your looking for! This advanced control module puts almost unlimited control right at your finger tips. The 2GO-PBS-II does the work of multiple control modules all in one clean easy to install package.
Each of the iTags™ hidden buttons is able to operate two individual feature channels by sensing the difference between a “Short Push” or a “Long Push”. These four independent selectable feature channels are user programmable (either Latched or Pulse) so they can be used for virtually any option such as Remote Keyless Entry, Shaved Door “Pop” (single/dual), Remote Trunk release, Automatic Window Roll up, Lighting or Video activation or whatever else you can dream up. In addition, the PBS II has a 5th "Proximity Channel" that activates automatically when you approach your vehicle. This channel can be used to activate lighting or any other device you choose. Very Cool!
Being able to select whether the iTag™ operates in Manual or Automatic mode allows you to control what features YOU want to operate at a car show while still keeping your vehicle completely protected.
iTags™ are powered by an easily replaceable extended life lithium battery that typically lasts one year. Up to 5 unique ITags™ can be programmed into each system, Additionally a single ITag™ can be programmed into multiple vehicles allowing its user to operate all his / her vehicles, motorcycles, boats or other toys by carrying just one ITag™. Ruggedly made from high impact material, ITag™s reliably perform first time every time.
MCB Parts - Matt's Classic Bowties
5360 Gateway Plaza Dr.
Benicia, Ca. 94510
866-628-8746
TEXT ONLY: 925-989-9091 (Replied 8-4)
www.mcbparts.com
Email: [email protected]
Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts
Hours: Monday to Friday 8am - 4pm Pacific
We ALWAYS enjoy talking to our customers!
We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking!
Old 09-26-2014, 12:27 PM
MCB Matt's Avatar
More and more of our customers, builders/shops are picking up these systems from us and getting them installed.. they are THRILLED with the kits!
It adds a huge convenience when it comes to accessing you car, especially if you are using your keys still, chancing scratching your car.... It's really not worth it with a nice paint job.
This system allows you to simply leave you keys in your pocket, approach the car, it will recognize the RFID key which is so small most keep it in their wallet, it measures 2.7" x 2" x 1/4" is all!
The kit also includes a true credit card size backup key for your wallet so if you decide to carry the remote in your pocket and loose it, you can still get in as long as your wallet is on you! This is all available for $250!!
One key can operate multiple cars if you want as well! The system will notify you of the lock and unlock process by flashing the parking lights and if a door is left open it will alert you.
The remote has a second channel output so you can program whatever you want off that channel like power trunk release, lights... Anything you want really.
Once you are about 2 feet from the car it unlocks for you! Once you turn the car off and shut the door and start to leave, it locks the car for you!
These systems are available as JUST a push button start, JUST the RFID keyless entry/exit or as a combo package. Remote start feature can also be added to the system!
Contact us for details on these kits, it may seem a little intimidating but we can explain the different options.
The top of the line kit includes: Push Button start, Passive Keyless entry, Alarm and remote start all in one system!
Thanks for the purchases on these systems!
MCB
Benicia, Ca. 94510
866-628-8746
www.mcbparts.com
Old 10-17-2014, 01:03 PM
MCB Matt's Avatar
Thank you all for the continued support here on the forums! We are proud to provide you guys with great service and prices on all of your purchases!
Thank you very much for the orders and happy FRIDAY!
MCB
Benicia, Ca. 94510
866-628-8746
www.mcbparts.com
Old 10-30-2014, 09:47 AM
RussMurco's Avatar
RussMurco RussMurco is offline
That looks like an awesome system! When I get to that point in my build I'll be calling you up!
Russ "Murco" Murray
http://i1339.photobucket.com/albums/...psc7bc7b5c.jpg
"Liquidating excess cash through the automotive hobby!"
Old 10-30-2014, 10:42 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Anyone have pictures of the push button installed in a 67/68 Camaro?
Curtis
Old 10-30-2014, 10:53 AM
MCB Matt's Avatar
Sounds good! We will be happy to go over the systems with you!
MCB
Benicia, Ca. 94510
866-628-8746
www.mcbparts.com
Old 10-30-2014, 10:55 AM
MCB Matt's Avatar
We don't have any pics yet, I have seen it in person and I will try to get some at SEMA next week.
It's a great install in a 67/68 car though because of the ignition switch placement.
There are several switches to choose from and they fit CLEAN in that spot, it will be a very good look if that is your concern.
Matt
Benicia, Ca. 94510
866-628-8746
www.mcbparts.com
Old 10-30-2014, 11:58 PM
Spiffav8's Avatar
Lateral-g Moderator
Matt
Thanks Matt. I will also be at SEMA next week and will be on the look out. Looking forward to seeing what you find.
Curtis
Old 12-04-2014, 01:41 PM
MCB Matt's Avatar
We wanted to thank all of our regular and new customers who took advantage of our Black Friday/Cyber Monday sales!
This was by far a record breaking sale / Year for us at MCB and we truly appreciate your business!
If you contacted us during the sale and were not able to complete your order before the sale end date, we will still accept your orders for the rest of the week! We were very busy and could only get so many orders entered, PM's replied and invoices sent.
We have many more exciting new products coming soon as well as sales! As always, your forum discounts apply throughout the year so let us know what you are after, we carry more Pro-Touring and stock restoration brands than just about anyone out there!
Remember, price increases typically always go into effect at the first of the year. We have no control over this and all we can do in encourage you to get your orders in if you can before then to save some cash! We will post Price increase dates as we receive them.
Happy holidays and thanks again from all of us at MCB
Benicia, Ca. 94510
866-628-8746
www.mcbparts.com
Old 12-18-2014, 10:57 AM
MCB Matt's Avatar
Just a reminder, many of our sales are still active, just give us a call, PM or Email for your price.
Thank you guys very much for the business this year, we have seen another amazing increase in new customers and sales.
We have added several new lines this year and will be adding dozens more in 2015.
We offer year around forum member discounts on 99% of the brands we carry as well as great customer service, we are always here 9-5 to answer your calls, no voicemails or automated phone systems!
We have the product knowledge you need/expect to guide you through your entire build as we carry just about every single brand out there and have spent thousands of hours researching, installing, teching and putting together packages for customers.
We work with every type of customer from beginner DIY guys that need our guidance to select the correct parts and how to install them all the way to several hundred builders that buy exclusively from us for all of their projects which equates to thousands of cars per year.
Again, thank you to everyone who has done business with us, we truly appreciate it!
Happy Holidays
MCB
Benicia, Ca. 94510
866-628-8746
www.mcbparts.com
