Old 09-17-2015, 10:56 AM
Musclerodz's Avatar
Default Need advice, 70 Mustang 428SCJ
I never come on asking for advice but I am at a complete loss on this one. 70 Mustang 428 SCJ, all new all factory correct. Engine runs all day in shop. I go drive it and will die inside a mile. It will restart on prime but won't stay running. I have changed the fuel pump, have fuel pressure gauge on it and is not dropping fuel pressure, I have changed the coil as well, checked everything with the Holley carb. I have no restrictions I can find in the fuel system either. It acts like it running out of fuel. I have considered its either sucking air or vapor locking, only thing I have not done is rig up a temporary fuel pump. Any ideas.?
Mike Redpath
Musclerodz & Customz
facebook page
Old 09-17-2015, 11:13 AM
65 347's Avatar
65 347 65 347 is offline
Mike
If you are running all factory stuff, the fords are famous for the ignition module dying, it will shut off park, then will reset itself and you cant find the problem. Hope this helps.
Mike
Old 09-17-2015, 12:51 PM
dontlifttoshift's Avatar
dontlifttoshift dontlifttoshift is online now
Gas cap vented?
Donny
Old 09-17-2015, 01:05 PM
Musclerodz's Avatar
Gas cap vented?
Its a CA emissions car, non vented cap with the vent line running to canister up front. I have attempted to drive it with cap open, same results
Mike Redpath
facebook page
Old 09-17-2015, 05:21 PM
Factory carb? Is there a stone filter on the inlet into the bowl?
Donny
Old 09-17-2015, 08:05 PM
Musclerodz's Avatar
yes, its clean
Mike Redpath
facebook page
Old 09-17-2015, 08:54 PM
zz430droptop67rs's Avatar
zz430droptop67rs zz430droptop67rs is offline
I know you said it doesn't lose fuel pressure, but how about the sock in the tank?
Old 09-17-2015, 09:18 PM
Musclerodz's Avatar
brand new tank, brand new sending unit, brand new lines. I have not pulled it yet, but I am considering pulling it next for good measure.
Mike Redpath
facebook page
Old 09-18-2015, 07:11 AM
Ketzer's Avatar
Ketzer Ketzer is offline
Old 09-18-2015, 07:44 AM
Originally Posted by Musclerodz View Post
yes, its clean
Is it safe to assume that you removed the filter and test drove it?
I'm out of ideas.
Donny
