Old 05-21-2007, 01:28 AM
Dipped's Avatar
Dipped Dipped is offline
Default First Gen F-Body LS-2
If I'm installing an LS2 in a 68 Firebird are my only options for a shorty header S&P? I was told an exhaust manifold from a ls1 camaro/firebird will also fit?
Old 05-21-2007, 07:27 AM
camcojb camcojb is online now
ATS and Hooker have full-length headers that will fit, depending on motor mounts used. There may be a stock manifold that clears, but I wouldn't want to give up the power and torque of the full-length headers.
Old 05-21-2007, 08:12 AM
PTAddict PTAddict is offline
Also, Stainless Works makes long tubes, and Wegner Motorsports makes 4-2-1 shorties:
http://s41657.sites80.storefront-hos...x?CategoryID=9
Not sure the wegners will fit a stock subframe, I know they fit a DSE front clip.
Old 05-31-2007, 02:49 AM
tyoneal's Avatar
tyoneal tyoneal is offline
What would be the difference in hp and torque between long tube headers and short tube headers?
Long Tube =100 hp/100 torq
Short Tube = ??? hp/ ??? torq
Thanks,
Ty O'Neal
Old 05-31-2007, 07:53 AM
Thanks,
Ty O'Neal
Good long tubes are worth 25-35 ft. lbs. down in the low/mid range on a decent small block, sometimes more on some combos. Probably less on a milder combo with cats.
I do remember doing a 458 hp 383 LT1 in my 93 Vette, and Myron Cottrell at TPIS begging me not to run shorties, which I wanted for legality here in California. He quoted the same numbers and seem to be pretty close to what I've seen through the years.
Old 05-31-2007, 08:14 AM
There are probably hundreds of posts on LS1Tech.com relating to this topic, but to generalize, on a performance cammed 5.7L or 6.0L, shorties are worth minimal to no gain over stock manifolds, long tubes can be worth 20-30 HP and maybe even a bit more than that in torque. The higher end designs with merge collectors do seem to be somewhat better than the conventional cannister-style collectors, but not hugely so.
Edit: Funny, I was typing my response before I saw Jody's, so there seems to be some consensus here.
Old 05-31-2007, 08:31 AM
We have a set of Stainless Works that will be finished in a couple weeks if you need some.
Frank Serafine
