Old 01-08-2008, 02:42 PM
TOM NELSON TOM NELSON is offline
Default 447 cube ford small block pics and dyno
Well we just finished a really neat little ford .I fiqured you would like to see.Specs 447 cube windsor 9.5 deck clev.main Special cnc Afrs Hilborns converted to electronic injection 9.5 compression 390 lbs open spring load a real street warrior the motor made a table flat 584 ft lbs and 627 hp at 6200 rpm and carried 600 hp past 7000 rpm.Revs like an explosion i attached some shots and a dyno graph really nice power for a daily ride. www.nelsonracingengines.com
Old 01-08-2008, 02:45 PM
Default Dyno print out
Here's one of the dyno runs
Old 01-08-2008, 02:56 PM
rwhite692's Avatar
Nice, Tom. The Ford guys on here will appreciate seeing you giving the SBF some love...
Project update thread here:
My Lateral-G Page
My Shop Build:
Old 01-08-2008, 03:47 PM
byndbad914's Avatar
byndbad914 byndbad914 is offline
would you share the cam type (hyd roller?) and specs?
Old 01-08-2008, 04:05 PM
COYBILT's Avatar
COYBILT COYBILT is offline
once again another beautiful nelson product.
Oh Tom did I mess that crate up when I over tightened the bolts?
1965 GTO convertible
2009 GM Design Award winner
Triple black with Subtle yet massive Modifications.
Old 01-08-2008, 04:17 PM
Default Cam type
It's a new type of grind for a solid roller very mellow valve acell and quite valve noise you can lash it at.012 but you get the benefits of being able to rev it.we devolped it for the turbo's originally,and sarted making ne grinds with it .
Old 01-08-2008, 06:36 PM
DRJDVM's '69's Avatar
Now its time for a modern HEMI
Old 01-09-2008, 12:39 AM
byndbad914's Avatar
familiar with those.. given the rpm I figured it was a low-lash "street roller" style grind or hyd roller with a rev kit or the newer-style lifters with little adjustment so they can't pump down and lash. I enjoy building the 440-460 inch small blocks as well
